Question about Garmin nuvi 205W GPS Receiver
Garmin 205 how to charge on computer?
Garmin nuvi 205 how to charge on computer?
  • Garmin Master
  • 6,993 Answers
follow the steps below:
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disappear.
Good luck.
Posted on May 27, 2010
bunnydawg
  • 5158 Answers
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
Posted on Feb 02, 2009
sharcnet
  • 2130 Answers
SOURCE: my Garmin Nuvi doesnt charge
I've received many units for repair where the customer thougth that the battery was bad because the unit would not turn on or stay on long.
The problem was really caused by broken connections on the mini-USB jack. Please see this link for more info, specifically look at the section dealing with the mini-USB connector.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Posted on Oct 22, 2009
  • 10865 Answers
SOURCE: my garmin nuvi 205 is not talking
hello. Begin by turning the volume all the way on. It is the little dial on the upper right side of the garmin. If that doesn't give you sound, return the unit as it is under warranty.
Posted on Dec 06, 2009
sharcnet
  • 2130 Answers
SOURCE: I have a garmin Nuvi 205. When I turn it on, it says
Please see this link regarding this issue:
http://www.sharc.net/discus/messages/6/250.html?1254844672
- Jim
Posted on Dec 09, 2009
emissionwiz
  • 75797 Answers
TIME FOR A TRIP TO GARMIN
Posted on Feb 26, 2010
Garmin nuvi 205 is not recognized by garmin updater or by garmin site while trying to register
Make sure that your 205 is fully charged and that the usb cable is plugged directly into a usb port on your computer and not thru a usb hub.
Thanks for using FixYa
Apr 24, 2011 | Garmin nuvi 205W GPS Receiver
Tip
Garmin Nuvi 205 Favorites Backup and Restoration Procedure Would you like to...
Would you like to back up a copy of your Garmin Nuvi 205 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205 GPS Receiver
My garmin nuvi 205 will not power on. I have plugged it in to charge the unit and it updates maps and shows the charging screen. Afterwards I unplug the unit and slide the switch over and it will not power...
This is likely a failed battery.
The battery on these units is not user-replaceable (soldered to the PCB) and must be returned to Garmin for repair.
CLICK HERE to see more about their FLAT RATE repair service.
Your nuvi 205 is listed as a $79 flat rate repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 16, 2010 | Garmin nuvi 205 GPS Receiver
Garmin won't charge or turn on.
Hello :
How old is your battery ? I think that the battery life is ended [ can't be recharged anymore ] . Just replace it and problem will be solved .
please rate !
Apr 14, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205 wont boot up
If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
Then attempt a hard reset.
Finally, replace the firmware and system software using webupdate.
I hope that helps.
Apr 03, 2010 | Garmin nuvi 205 GPS Receiver
Yesterday my Nuvi 205 worked fine, today it will not turn on. I have verified with another unit that the charge cable is fine and the other units charger will not activate my Nuvi
Then I suggest attempting a hard reset.
Finally, replace the firmware and system software using webupdate. Your Nuvi should not need to be able to power up for a firmware update to be possible - replacing the firmware should allow it to power up successfully after the update.
I hope that helps.
Mar 27, 2010 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 205 continues to state Loss Satellites
Then I suggest a hard reset. This correct some problems.
Finally, replace the firmware and system software using webupdate. Replacing the firmware should allow it to find more satellites more quickly and keep them more successfully after the update.
I hope that helps.
Mar 14, 2010 | Garmin nuvi 205W GPS Receiver
How can i charge it if my car smoke thingy doesnt work?
Plugging your Nuvi into a computer's USB port will charge it. You can also use a powered usb hub that has a wall-power plug to act as a charging station for your nuvi without needing a computer at all.
Mar 11, 2010 | Garmin nuvi 205W GPS Receiver
Just bought garmin nuvi tested it on ride home and
Probably not! it should be fully charged before use and from the sho they never are fullyt charged.
Sep 19, 2009 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
396 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
