Question about Samsung LE32R72B 32 in. HD-Ready LCD Television
Tv does not communicate with remote control. Stand by light on tv fades away. Batteries on remote control have been replaced. It's a problem on the tv. the remote control is ok
  • 94 Answers
Defective IR sensor or main board
Posted on May 28, 2010
My TV will not turn on. A small red light is blinking at the left lower front of the TV. What can I do to make it work?
TRY CHANGING THE BATTERIES ON YOUR REMOTE CONTROL OR, IF THAT HAS DIED, YOU MAY NEED TO REPLACE.aFLASHING RED LIGHT IS INDICATIVE OF STAND BY MODE.
May 27, 2015 | Televison & Video
The remote control sensor on the TV has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 09, 2012 | Televison & Video
T.v. does not respond to remote control, but does work maually from side buttons
Turn tv on manually.Test the remote control all functions are dead or some functions work other don't?Tries take the remote control parts and clean the inner rubbers buttons between the rubbers insulater and the remote circuitries board and the battery connections + - connections with some rubbing alchahol.Then wait awhile like 20 mins and putting it back together again and putting in new battery in the remote,it might work again.If getting the same result than the remote CPU chip is probally dead,remote control devices are very depended on it CPU chip.Try website like Remotes.com to buy an original remote for the replacement.
Mar 24, 2011 | Vizio 42 in. LCD TV
My remote does not work on my tv I have change the batteries but I notice that thre remote control sensor light does not blink or the OPC sensor. We have to turn on the tv manualy and to change channels...
Good luck.
Mar 02, 2011 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Remote want work on tv
Make sure that you're using the supplied Remote (RMY-906) to control the TV. If so, perform the steps given below to resolve the issue.
  • Make sure that you're using batteries which are having enough charge. Try using fresh alkaline batteries.
  • Do not use rechargeable batteries in the Remote.
  • Ensure that the batteries are inserted correctly with the correct terminals by checking the + and - symbol in the battery compartment.
  • Make sure that the Remote is set to operate with the correct functions. On the remote control, press the TV FUNCTION button to re-check this.
  • Press the POWER button and other buttons to test the operation.
  • Make sure that none of the buttons are jammed in the remote control.
  • Ensure that the remote control is being used no closer than 3 feet and no further than 10 feet away from the unit. Try using the remote control at varying distances from the TV.
  • When using the remote control, be sure to point it directly at the remote sensor on the device.
  • Remove any obstacles that may be in the path between the remote control and the device.
  • Ensure the remote sensor of the device is not exposed to direct sunlight or bright florescent lights, as this can interfere with the sensors ability to receive signals from the remote control.
  • Try resetting the Remote. To reset the Remote. remove the batteries from the remote control, press every button twice, and then reinstall the batteries.
  • Try resetting the TV also to check the operation. To reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power on the television.
If the remote control is able to operate other devices (such as cable box, DVD Player or satellite receiver), then the issue may be with the IR sensor on the TV. If this is the case then the TV that will require service. Otherwise, the remote control may need replaced.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony KP-61S75 TV
Philip 29PT6021 switched off suddenly
Capacitors problem in vertical circuit
Sep 12, 2009 | Sony KV-32FV1 32" TV
Direct tv remote batteries fail constantly
I have same problem with Dish TV.........I was told the 'fix' was to press satellite button, on the remote, after turning off the telly. There is no permanent resolution - Problem occurs as remote is always communicating with the box when it's in TV mode (which happens after you power off the tv).
Aug 29, 2009 | RCA DIRECTV Satellite Remote Control
Remote does not seem to be communicating with TV.
I presume you have replaced the batteries in the remote control and had it checked to confirm it is working if so the most likely cause of faliure to come out of stand by is a currupted eprom (memory chip) within the TV and will require a technician to replace or reprogram
SUPER8
Nov 11, 2008 | Televison & Video
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Sometimes remotes have a switch to select tv,vcr,or cable,amke sure the remote is in the tv mode,other than that rare but remote receiver go bad and they have to be replaced,but before you call for assistance make sure the remote is communicating with the TV.It could be still good with other devices and not with the set.
Sep 27, 2006 | Panasonic CT-34WX54 34" TV
Samsung LE32R72B 32 in. HD-Ready LCD Television Logo
194 people viewed this question
Henry  Thomas
Henry Thomas
