Frigidaire washer mod.#fwsb5700dso makes noices when in spin ,don;t sound like a bearing more of a thump than a wine ,also sound coming from the inside bottom of tub thanks
    Top Expert:
  • Washing Mach... Master
  • 78,267 Answers
This is most often a bearing, u don't hear the bearing but the washer tub jumps all over the place and makes the thumping noise.
Posted on May 27, 2010
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Scraping, thumping, and whining sound as the washer drum spins. sounds like something may be loose inside. sounds like a loose belt squeeling?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 19, 2011 | Frigidaire Washing Machines
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Loud thumping noise during spin.......not related to unbalance....manually turning the tub makes a loud noise.
Bearings shot or counter weights have come loose
Take the top off and check the weights first
Jan 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer makes thumping sounds when spinning even without a load
Check under washer to see that you have not got a broken spring that is causing the drum to spin out of round.
Thanks for using FIXYA
Sep 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Loud thumping while spinning
my friend had this happen,apparrently a bearing was leaking then finally broke!
Jun 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Washer 110.94818200 Spin Grinding Noice
the bearings are bad and yes they can be replaced but a service tech will have to do it. very big job
Jun 22, 2008 | Washing Machines
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
