Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
3 flashing lights when attempting power up
Your answer:
That is indicating that the convergence circuits have shutdown the set. You will need new Convergence ICs. They should be STK392-110 or STK392-120 either number works the 120 being the better chip. I will post a link where you can get the new ICs and they provide step by step instructions with pics so you can do the repair yourself. You will find your IC numbers under the section titled Convergence ICs just click on that and you will find your STK numbers.
http://servicemanuals.vstore.ca/
can this repair be done by most anyone?
  • martinguy Apr 07, 2008
    does this blog show the basics of getting to the convergance ICs
    and the link you provide on the parts page take you down the same path?
    Also any other links to prep me for the task? As you can tell I'm willing (to save huge bucks) but slightly intimidated. I'd really like to study up on the process just a bit. Make sure I can avoid the big mistakes.
    This is extremely helpful.
    Thanks
    I think I forgot the link I referenced. Sorry
    http://cmpalmer.blogspot.com/2006/11/fix...
Xvbxcvcx
Posted on Apr 07, 2008
  • Panasonic Master
  • 8,617 Answers
Yes It is a simple repair as long as you have the proper instructions and have the tech online while your doing it. The link I posted has excellent instructions with pictures and I am one of the support techs that provides the on line instant messaging while the repair is being done. The instructions even explain the proper way to solder and unsolder right down to the type soldering iron to get at radio shack. However the site does offer a service where you can ship the board to them and they will install and ship it back to you.
  • Sonny Berry
    Sonny Berry Apr 07, 2008
    Yes thats a good blog. Its actually a easy repair. If you order the parts from the link I provided they will have a tech online that you can instant message while doing the repair hust in case you have any questions before, during or after the repair. Heres that link again in case you want it.
Toshiba 51hc85 will not show picture red power light flashes where is reset button and or fuses What else could it be
This set does not have a reset button. The flashing light means shutdown and the most common cause is a short in the Convergence circuit.
Way to prove or disprove this is someone has to get at and unsolder both chips used--usually two stk-392-110 or similar--18 pins each.
If set comes on then one chip is bad but both must be replaced.
There are resistors around the chips that fail and that triggers the shutdown. Also most of these have pico fuses that are not glass and are tied to different areas of the set--one of them goes and shutdown is the result--they are green or orange and look like a resistor but have the amperage marked on the board next to them---two of them protect the convergence circuit and are usually 3 to 5 amp---can be tested with set unpowered just like any fuse--no reading across and bad.
set may have as many as 7 of these all in or near the power supply.
Nov 06, 2012 | Televison & Video
My tv button keep flashing on and off how can i fix this
I am more than willing to help but need more information.
If the red power light is just blinking when you try to turn the set on it means the set is in protective shutdown.
The most common cause for this is one of the two convergence chips used is shorted.
I can tell you how to prove if this is the case or not, I have answered a lot of questions here and am highly rated. I never know the skill level of the person asking so try to tell me something:
Can you solder? If I point you in the right direction (only one I know) can you attempt something?
I am here to help and not talk down to you but some people can attempt what I have in mind and others cannot.
In this case it would involve getting at the two STK-392-110 convergence chips and unsoldering both---if one is causing the problem the set will come on with them removed from the circuit and you will have a fairly inexpensive repair.
The more you tell me the better I can help you.
Before you rate this information let me know what you can or cannot do.
SD TECH
Aug 16, 2011 | Toshiba 55H70 55" Rear Projection...
No pictuer no sound
your user manual will have the flashing light code structure indicating the fault that caused the shutdown there is no thermal fuse in your TV
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Apr 28, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My screen is blank and the power button keeps flashing blue
AV56wp74? The power button blinking blue means the set is in shutdown----the most common reason for this in this set is one of the two convergence chips is shorted. The way I usually prove this is to remove rear cover and or front grill and examine convergence circuit located at the front of the set----Also--I will unplug the plug from that circuit board that goes to the TV's power supply---if the set turns on with the convergence circuit board unplugged from it---you know your trouble is one of the two chips---if this is the case both have to be replaced and the set adjusted.
I do this here for free so if this has helped you give me a vote here. If you have questions or need help let me know.
Aug 27, 2009 | JVC AV-56WP74 56" Rear Projection...
Blinking red light
Your TV is in shutdown. Unplug the set from the wall and wait 30 seconds. Apply power and see if the set comes back on. If the problem is the same (red blinking light) then you need to call a repairman. The most likely suspects are the convergence chips , vertical loss, power regulator or horizontal circuit problems. The shutdown circuit monitors multiple circuits for voltage and current malfunctions. That is why you need someone trained to troubleshoot the problem. Good luck!
Nov 23, 2008 | Toshiba 57H81 57" Rear Projection...
WS-55807
Good Day;
Shutdown at Power Causes: Cause #1 This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Sep 16, 2008 | Mitsubishi WS-55807 TV
Panasonic pt-53wx53g tries to turn on but goes right off
Mar 30, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Toshiba projection tv
Unplug the TV from the outlet for about 30 seconds. This will reset the microprocessor. Re apply AC and power on the TV. If your lucky the set will come on and play. If not, the red light will start blinking again indicating shutdown. There are many reasons for the set to go into shutdown, but one of the most common cause is failure of the convergence output IC`s. If your TV is in shutdown, you will need to find a qualified technician for proper diagnosis and repair.
Nov 23, 2007 | Toshiba 57H81 57" Rear Projection...
Mitsubishi will not turn on
If the green light flashes, thats an indication that there is a problem in the sweep power supply or the horizontal drive circuit. Its not a problem a layman or unexperienced person should attempt to repair unless you know about electronic circuits and how they work.
Sep 22, 2006 | Mitsubishi WS-65511 65" Rear Projection...
Black has turned blue and shutting off
That usually means the x-ray protect circuit was triggered. The set is going into protect shutdown for some reason. It may be a valid trigger to a lame problem or a fault in the detection circuit itself. I would hang a scope on there and just watch to see if there is a strange movement in voltage values, and if so, troubleshoot it from there. The blue picture is a result of a convergence problem. If you don't know much abou TV repair, I would suggest taking it to a Toshiba authorized servicer for proper diagnosis.
Jan 29, 2006 | Toshiba 32A43 32" TV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
