Question about RCA HD61LPW42 61" Rear Projection HDTV
RCA HDLP 50W151 scenium color wheel
We replace our color wheel this weekend. Turned on and no screeching but the colors are off. Any suggestions? Does it somehow need to be synched? PLEASE help.
  • 5 more comments
  • dgast Apr 09, 2008
    the color wheel part number is 212184. Where do I find the chassis number?
    Thanks!!!!!!!! I will check it when i get home and post again! Great help!
    How do you get to the serviceman menu?
  • dgast Apr 11, 2008
    Hi, well we got to the service menu and got the new color wheel in. You directions were great. But it seems that the red and blue are backwards. What is supposed to be red is blue and vice verse. Any solution to this?
    Any luck? All the people are smurfs.
    Is the phasing in the service menu?
  • dgast Apr 12, 2008
    Still no luck. Can you send the link to the manual?
does the indexing procedure work also with the HD44LPW164 TV? My problem is that i have some small green shadows around small red objects, for example football players if i watch sports. Maybe the index procedure helps?
Is the green colour automatic on the tv screen ?
Posted on Jun 17, 2008
  • RCA Master
  • 8,617 Answers
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Posted on Apr 07, 2008
  • 4 more comments
  • Sonny Berry
    Sonny Berry Apr 09, 2008
    your chassis is the ATC311M and the color wheel is correct here is the info on how to index the color wheel properly, And If you would like the full factory service manual for your set let me know and I will post a link where you can get one over 300 pages emailed to you. Write evrything down when you enter the service menu.
    Color Wheel Index Adjustment
    The Color Wheel (CW) Index adjustment is best done using Chipper Check.
    However, if Chipper Check is not available, the CW adjustment can be done using
    the Serviceman Menu.
    To do the CW adjustment via the serviceman menu, access service menu 80. Once
    in service menu 80, use the input button on the remote to toggle through until the
    display reads Color Wheel Index. To make the adjustment start by noting what the
    value is. Using the volume down, adjust until the green color starts to fade. Note the
    point where the green screen starts to fade and write down the value indicated as
    stop point A.
    Next, using the volume up, run the value back through the starting point and proceed
    until the green starts to fade in the opposite direction. Make note of this value as well
    and write it down as stop point B.
    Now using the two stop points (A and B), find the center value between the two. This
    is done by subtracting point A from point B, dividing this value by 2 and adding it to
    point A. This value will be the middle point between point A and point B and also the
    Color Wheel Index value.
  • Sonny Berry
    Youre welcome let me know if you need further assistance.
  • Sonny Berry
    Sonny Berry Apr 11, 2008
    I will check and see what I can come up with on that and will repost after I check the logs on that issue.
  • Sonny Berry
    The tint is controled by the phasing (speed) of the color wheel. try tweaking the index value to see if this helps bring it back with in the proper tint range. Still searching for a detailed proceedure for you.
  • Sonny Berry
    Sonny Berry Apr 12, 2008
    Thats the Indexing proceedure I posted above. try tweaking that a little and see if it will dial in the tint .
  • Sonny Berry
    Heres the link to the service manual. You will want the ATC311 DLP training manual , because if you get that one they include the extra service manual with it that breaks down every phase of the RCA dlps. You'll be emailed 2 seperate manuals the ATC311 and the ATC32xx series which are the same but the second larger manual gives all the indexing info for all theDLPs.
Were can I buy a "light engine" , part number 26589 for a hdlp 50w151 television ?
26589 This is the actual part, which they have none of...but on this page they say this part can replace that one fine: 261589DX
Aug 05, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Replaced bulb assembly in RCA DLP but screen is very dim
Sounds like your light engine is damaged. Could be cracked. You can replace it for under 100.00 which includes a new engine and color wheel as well.
Aug 03, 2017 | RCA Scenium HD50LPW52 Replacement Lamp
Buzzin sound not fr the lamp on a scenium hdtv
On DLP TV that sound is probably the color wheel bearings.
Apr 15, 2010 | V, Inc. VIZIO RP56 Rear Projection...
I have a RCA Scenium HDTV DLP that has a whinning sound and no picture. Could this be the bulb?
No, this is the color wheel. I have a tip at which explains in detail how to change the color wheel and where to get the parts.
Thanks for using FixYa and for the generous rating.
Mar 06, 2010 | RCA Scenium M50WH187 50" HDTV
Need a color wheel for RCA Scenium HD50LPW165 50 in Rear-
that color wheel has been discontinued by RCA. Its the 267888 color wheel. You can get your color wheel rebuilt at the following link under color wheels.
Oct 16, 2009 | RCA Scenium D40W20 40" Rear Projection...
How can i check my lamp ballast in a rca scenium 50w151 everyone tells me its my color wheel because i replaced my lamp and since then my tv wont even start up the light blinks then it stays on for a while...
are you sure when you replaced the lamp you seated it correctly, no really hapens all the time so dont feel bad. also another common error is the lanp door is not seated or closed and locked properly that is the most common problem that happens after a lamp is replaced, or the new lamp is bad never throw out your old one as somr dealers will give you what they call a core refund , they reuse the case around the old lamp. some can be worth as much as 50 to 60 bucks!!!
Larry Dillon
Sep 04, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
No picture and loud screeching on RCA Scenium 50" DLP
It sounds like it is the Color Wheel. I do not think you can get the Color Wheel separate from the Optical Engine like you can with Samsung. RCA is very tight with there parts like that. Because you have to get the whole
Engine Assy, cost would be too much in my opinion to invest into it. The part cost approx 800.00 the last time I checked on one.
Good Luck,
I Hope this helped,
Jun 20, 2009 | RCA Scenium HD65W20 65" Rear Projection...
RCA Scenium HD50LPW166XY1 DLP Projection HDTV ''scream''
RCA has discontinued the color wheel for your model and its on nationwide back order, so you cant buy the replacement. You can get your color wheel rebuilt at the following link and the rebuilt color wheels are fully guaranteed.
Jun 14, 2009 | Televison & Video
Color is wrong after color wheel replacement
You probably replaced a bearing colorwheel, and it was replaced with a bearingless. If you look inside the TV on the back of the light engine (the silver box in front of and to the left of the color wheel), there should be a jumper (that connects two wires coming out) toward the bottom of it in a recessed little hole. That jumper should be removed if the color wheel was replaced with the air bearing type. Just grasp it gently with a pair of needle nose pliers, and pull it out slowly.
This should restore a normal color operation, but there might be some other adjustments that need to be made if it doesn't clear it up completely.
I hope this helps you...
Jan 22, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
1,642 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
