Question about Playskool Step Start Walk and Ride
How is the rectangular purple piece to be attached? Is it to enclose the handle? What size screws should be used to attach it? My daughter's child care person threw out the box containg instructions and the screws.
  • 4 Answers
See the booklet
Posted on May 28, 2010
Crouch strap
Hi
Please contact Graco for assistance with correct use of the harness
Get news from Graco delivered right to you inbox
May 10, 2014 | Graco Nautilus 3-in 1 Car Seat
Drain stopper and its attached three brass pieces have become detached from the vertical rod running up to the handle.
Should be a small screw, hex or wingnut that attaches pull rod to rest of pop up assembly, just re-attach rods and tighten screw firmly.
Nov 19, 2013 | Kohler Plumbing
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
How to remove hard drive cover for Toshiba Satellite L555D-S7930
On the bottom of your laptop should be a piece of plastic that is rectangularly shaped. It should have some small screws in each corner. Unscrew those screws and then slowly grab the hard drive and pull it up on the opposite end it is attached and once it is at about 45 degrees pull it out directly away from the area it is attached.
May 10, 2011 | Toshiba Satellite L555DS7930 Notebook
My steam pocket mop seems clogged. Steam does not come out of the mop head. The clog appears to be in the rectangular mop head. The triangular head still works fine. I've tried soaking it in hot water...
I had the same issue with the rectangular mop and corrected it by disassembling the tube from the rectangular piece. There are two screws that will need to be removed in order to get access to the connector. Once the connector is removed from the rectangular piece you will need to **** out the clog. I used a small drill bit and was able to do this without attaching the bit to a drill. There is a slight angle to the connector which causes the clog to occur. The total job took about 45 minutes to accomplish. I could have purchased a replacement for $21.95 but thought I'd take a shot at fixing it. Hope this helps.
Dec 19, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How do I get the hose off to clean furniture?
Just above the power button is the purple, ribbed section that pushes in for releasing the hose. You press in and lift to release the entire hose assembly. You then pull the hose down to separate it from the handle. Push in purple button at end of hose section to separate the two sections. Now just flip over the wand and attach to opening at top of handle by sliding into the round, vented purple cap until you hear a click. That's it! Now you can use as is or connect your attachments if you have them. Hope this helped!
Dec 06, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Door handle broke, can't open door from inside but still from outside
the inside door handle railings probably popped off, its a long bent to shape piece of metal running from the handle to the switch, you will need to take the inside door card off using a screw driver and popping the clips out, peel back the plastic cover enough for you to see, use a torch to see where it has popped off and clip it back in, if you try using the handle and you can hear the metal rod moving around it mights still be attached but the retainer clip has jumped off clip it back in. should solve your problem, if its all still in tact check to see if the child lock feature is working properly and isnt stuck to the lock mode. cheers hope it helps :)
Jun 22, 2010 | 1995 Buick Century
Vorwerk VK121 vacuum cleaner - smell of burning from housing enclosing motor. How do I get into the housing to inspect the motor? After tilting the bag sideways, there are two screws holding the housing...
yes the handle is clipped in place and should come out when the button in front is pushed. Remove the screws you wrote about. After that the puzzle begins. At the bottom of the vacuum where the head is attached, remove the head by pressing the button. This same button now needs to be pressed all the way through while pulling on the top of the motor base. The outer shell will slide off while the motor stays attached to the part where the bag is attached. After this the entire motor is revealed and the brushes can easily be replaced. Hope this helps. J. Franklin / Former salesman
Apr 13, 2010 | Vacuums
I just got the steam mop but it came without instructions, I don´t know how to assemble it. I´m not sure if I´m missing pieces
There should only be 3 basic pieces to this machine. The body housing, the top handle and the floor nozzle. The handle attaches to the body with a bolt and a nut and then the floor nozzle is just pushed into the body housing. That should be it.
Nov 30, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How do you remove the door panels from a 2001 GMC Sierra pick up
On the inside trim, you can remove screws (these screws may be covered by filler pieces or may be visible, or they may require you pry a plastic piece off that covers the screws) that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect any other wiring that may be attached to the door.
Nov 02, 2009 | 2001 GMC Sierra 1500HD
Playskool Step Start Walk and Ride Logo
160 people viewed this question
Top Playskool Toys Experts
ray gallant
Are you a Playskool Toy Expert? Answer questions, earn points and help others
