Question about AEG 24 in. Favorit 80860iW Built-in Dishwasher
Message -spray arm blocked
AEG Favorit 80860
All programs
Says sray arm blocked. Have cleaned arm and run empty- still says arm blocked.
Do I have a sensor fault.
  • Christopher Dowling May 27, 2010
    Hello, It may well be a faulty sensor.The model number does not exist on our system can you supply the product number found on the rhs. stainless steel edge of the door.I will get more information on the Dishwasher then. Hope this helps.
  • 901 Answers
Check water pump inside the machine for its full speed.If the speed is low check the capcitor and replace.
Posted on May 28, 2010
AEG FAVORIT DISHWASHER, PUMP KEEPS GOING WHEN TURNED OFF, UNLESS TURNED OFF AT MAINS
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
Nov 02, 2017 | AEG Dishwashers
Question relates to an AEG 80860 Favorit Dishwasher pnc 911371032. theb upper spray arm fell off and i have examined it and the central holding device. they do not appear to be damaged but when i tr
1. To remove upper basket spray arm, tilt it down hard.
2. Clean spray arms jets.
3. Place cleaned upper basket spray arm back in position against the connecting piece: press the two together
firmly, until you feel them snap into place.
Dado
Jan 13, 2015 | AEG Dishwashers
Aeg oko favorit 50500w water not coming in through spray arms
There are several reasons if spray arms doesn't spray water. First you need to check efficiency of circulation pump. If it works, then should check the turbine of circulation pump. Sometimes turbine blades can be broken and the pump does not produce enough pressure to turn the spray arms. Be sure to check that the filter is not clogged which can also causes same problem. Finally, check that the nozzles of spray arms are not clogged.
So, could be:
- motor circulation pump
- circulation pump
- filter
- spray arms
- electronic or power board
Dado
Jul 12, 2014 | AEG Dishwashers
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
I have an AEG Electrolux 80860 (free standing). It is not cleaning properly and keeps saying 'spray arm blocked'. I'm not sure what to do. I have run it on empty, tried to unblock everything I can see...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 13, 2010 | AEG 24 in. Favorit 80860iW Built-in...
AEG Favorit 665i. Lower arm does not turn
im not sure about this if the upper arm is working ok,because the lower arm gets the pressure first then sends it to the upper arm,if the water pressure to the machine is ok then the lower arm is at fault take another look at the lower arm something is not right with the lower arm.adrian;;
Jan 22, 2010 | Dishwashers
AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Jul 31, 2009 | Dishwashers
Dishwasher keeps cutting out
Has the door got heavier recently?
Mine had a spring break which fell onto the electrics and shorted them. Unplug and empty it, then tip it up to see if you can see a loose spring. If it is then replace or re-fit the old spring, I have posted instructions and pictures here:
http://www.howtofixanything.co.uk/howto-260.html
Jan 24, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Aug 23, 2008 | AEG 24 in. Favorit 40850 Free-standing...
AEG 24 in. Favorit 80860iW Built-in Dishwasher Logo
834 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
