Question about kawasaki Full Suspension Mountain Bike Men
1990 KX 250 electric come's and go's - kawasaki Full Suspension Mountain Bike Men
  • 1,284 Answers
Hi, please re-phrase your question. I don't understand what you mean by 1990 KX 250 electric come's and go's...
Take care
Posted on May 27, 2010
  • michaellexes May 27, 2010
    1990 Kawasaki KX 250 intermittent power for ignition
  • Shehu Pro
    Shehu Pro May 27, 2010
    First of all, how is the battery? Have you tested it? By your description I would say that's not the probably cause,but bad batteries have been known to do weird things. It might be worth it to have it load tested.
    Take off the connection on each of the battery cable (both ends) and clean them really good with a wire brush. Clean out the thread holes for any of the nuts/bolts and make sure there is no corrosion on anything. Put them back together and make sure they are all tight. If you still have problems, try the starter relay jump trick:
    Wear safety glasses just in case cause it's probably going to spark a bit. Take a screwdriver and bridge the two large connectors on the starter relay. If it turns over, then then you know the primary circuit and starter are fine. If not, I would check the starter out.
    If it does turn over, you have some more in dept testing to do. At this point I would get a service manual and a good multimeter and get ready to do some testing.
    Take care
I have a 1990 kaw kx 250 and it leakes oil from over flow tube but also oil is murky grey color and leaks from radiator over flow
blown head gasket... stop running it... it will trash the entire engine if you continue to do so.
Mar 25, 2013 | Cars & Trucks
I have a 1990 kx 250, just had the top and bottom end done. Rode it for four hours and it died! Replaced the cdi box with new one, replaced the coil and stator and I still have no spark'
chec battery-must always be at 12.6volts-any lower and bike wont function--inspect connections for corrosion--also make sure carb and fuel delivery are correct
Jan 08, 2013 | Motorcycles
I am rebuilding the top end of the engine and need toknow how to set timing
A KX 250 has no timing it is a 2 stoke motor are we sure it is KX 250 and not something else ??
Jul 02, 2011 | 2005 kawasaki KX 250
How much horse power does A 1998 kawasaki kx 250 have
There is reputed and there is actual horsepower!
A reputed 52.5 Hp for the 1990 is not right.
A reputed 57.5 Hp for the 2007 maybe right...at the crank.
You lose 8%-10% at the wheel, 5% more with an O-ring chain.
Standard KX250 would be around 42-45 Hp in peak condition. Intake mods, jets, expansion chamber and some porting changes may give you more but it's give and take...you will lose bottom or mid-range and tractibility will go out the window with a very peaky motor. Computer search KX250 forums and canvas the responses and also look for generic KX250 link's.
Cheers.
May 17, 2010 | Motorcycles
Fork capacity on 1991 KX 250
SILKOLENE PRO RSF 5WT or use
SILKOLENE FORK OIL LIGHT
500-MLS OIL EACH LEG
Mar 10, 2010 | 2003 kawasaki KX 250
Im looking for a 1990 dodge ram 250 wiring diagram is there any where i can find one for free?
wiring diagrams for a lot of vehicles (but not all!)
go to autozone . com
repair info (on the left)
vehicle repair guides (center panel)
put in your vehicle info
select chassis electrical
then wiring diagrams (on the right, bottom of the list)
The 1990 is available there. I have a 1990 250 and have used the page a few times.
Dec 03, 2008 | Dodge Ram 250 Cars & Trucks
Horsepower
I dont know about the '89 but i have read that the 1990 has about 50hp.
Nov 10, 2008 | 2006 kawasaki KX 250
kawasaki Full Suspension Mountain Bike Men Logo
43 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
