Question about Sony VAIO TX750P/B Notebook
Hi; my tx-750 vio wont start. the power light and blootooth/wireless light turn on and the booting makes a sound but never turns the pc on. i bought another charger but that did not help. iam very frustrated. please help.
  • sean sutton
    sean sutton May 27, 2010
    have you tried without the battery in? just with the power supply.
    Sergeant:
    Champion:
  • 256 Answers
You said booting makes a sound? So it powers on and makes sound. Therefore it is turning on but does not have any display, right? Try hooking an external monitor to test if it is the Lcd or the videocard that is causing this problem. I f it will show good display on external monitor then you just need to replace the Lcd of your computer, but if not, you may need to replace the motherboard since videocard is embedded on it.
Posted on May 27, 2010
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
How to configure symbol 5131 through hypertrm
Hi
You can set up the AP 5131 through Hyperterminal by accessing it through COM1 to start,
19200 bits per second
8 data bits
Parity: None
Stop bits: 1
Flow Control: None.
Good Luck. :)
Apr 22, 2010 | Symbol AP-5131
Just bought a Dell D610 and it won't connect to my wireless router. I try diagnostics and it says windows cannot finish repairing problem.
Try turning the router off for 15 sec. then power it up again waite until the LEDs are on then boot up the DELL laptop.
If you shutdown both the router and the laptop and power them up together, then the wireless router may not finish initializing when the laptop boots up and therefore the wireless router doesn't get a chance to issue an IP address to the laptop.
Make sure the wireless router LED lights are on before you boot up the laptop.
Dec 09, 2009 | Dell Latitude D610 Laptop Computer -...
Getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
Will not start
try to use first the vios. when turrn on the computer press del.
Feb 05, 2009 | Toshiba Satellite M35X-S114 Notebook
PC wont Boot/start
The first thing you should do is swap the power supply for a known good one,
If this is a new build that hasn't worked from the start follow the instructions here:
http://forum.pcmech.com/showthread.php?t=132409
Aug 27, 2008 | Computers & Internet
Hi please help me with my acer 3003 wont boot
try to power up with power cord only and see if it works. If no lights turn on than your motherboard is dead. If it turns on and nothing happens make sure there is memory installed(RAM). If it turns on and you see windows screen than it shuts off than your operating system needs to be installed again. Also, you can try booting in safe mode by hitting f8 when you initially start your computer and see if it stays on and if it does you have a virus most likely. Good luck.
Aug 18, 2008 | Acer Aspire 3000 Notebook
Sony VAIO TX750P/B Notebook Logo
139 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
