My notebook laptop model window xp Advert intell@atom. its on blank screan its says BOOTMGR ms missing, press Ctrl+Alt+delete to start again, if am doing that its return into the same page i have'nt got any cd-rom, what can i do?
    President:
  • 1,194 Answers
You could try a repair of xp this will keep your files.
1. Put your Windows XP Install CD into your laptop.
2. Reboot your computer.
3. Let your system boot off of the CD.
4. Let the Setup go through the first part of the Installation procedure.
5. When you come to the screen in which it says "Welcome to Setup." press Enter to Setup Windows XP.
6. Press F8 to agree to the End User License.
7. Let the Setup search your system for previous versions of Windows.
8. When the Setup is finished searching your system, select your Windows XP Installation and press the R key on your keyboard to start the Repair Procedure.
This is the part that might make you nervous . The Setup will delete all major system files and then replace them with new copies.
You will have to download all of the updates from Microsoft Windows Update again because it replaces the files.
Thanks for using Fixya.
Good Luck and have a nice day.
Posted on May 27, 2010
Toshiba satellite l500 bootmgr missing.
please calm down. do the follow steps.
Restart HOLD the CTRL key +f11 or f12 Depend of your model, mark., and go to restore the factory default and ready.
If doesnot work. restart again HOLD the CTRL key+f8 and use the last o.s was working and ready.
God bless you
Jul 06, 2013 | Toshiba Satellite L500 Series Notebook
When I start the PC it says "BOOTMGR is missing"
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Nov 12, 2010 | Acer Aspire 6920 Notebook PC
Hi . Iam ASHOK . my Laptop hava some problem (BOOTMGR IS MISSING PRESS Ctrl+Alt+Delete .) my laptop configuration is intel 3i Pro, Hdd 500 gb , Ram 4gb , OS is Windows 7 . place help me ...............
Hi Good day!! There might be a corrupted files in your windows (BOOTMGR) you will need a windows 7 CD
* Insert your Windows 7 disk into your DVD player and restart your computer.
* The next screen you see should have the Language, Time and Currency and Keyboard boxes.
* In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
* Click on "Repair your computer"
* Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
* Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
* You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
* When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
* At this point, you can remove the DVD, reboot and everything should be working.
Thank you for using FixYa
Please accept if my solution helps you!!
Nov 08, 2010 | Dell Computers & Internet
My laptop is on black screan its says BOOTMGR ms missing, press Ctrl+Alt+delete to start again, if am doing that its return into the same page , what can i do?
1. Put your Windows XP Install CD into your CD-ROM drive.
May 27, 2010 | Microsoft Windows XP Home Edition
Bootmgr is missing on Windows XP System. Gateway
Bootrec /rebuildbcd
May 15, 2010 | Gateway ML6721 Notebook
Download this Recovery Console BootCD
http://www.thecomputerparamedic.com/files/rc.iso
Burn the image (ISO) to CD.
Boot from the newly created Recovery Console BootCD
Log into the Administrator account (press 1 then press enter)
On the command prompt type: chkdsk c: /r (and then press enter) Note one space after "c:")
Once CheckDisk has finished repairing the faults, type Exit, and then Restart (remove the BootCD)
Mar 29, 2010 | Gateway ML6721 Notebook
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
My gatway ml6721 when it starts it say gatway then it say bootmgr is missing press ctrl+alt+del
What is your operating system. Is it a Vista or XP? Either way, it is easy to resolve if you have your Windows DVD or CD that came with your computer. If it is a vista, try this link:
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Nov 08, 2009 | Gateway ML6721 Notebook
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
