Question about Logitech QuickCam® Chat Web Cam
Dont work on messenger
It dont work on messenger but it did befor, i have done everything i know. but it dont works on msn. But it works on everything els.
what to do?
  • 2,764 Answers
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Posted on May 28, 2010
Hi. the problem is whenever i signed in my msn it opens for a second and then a box with an Error pop up, choices are "Dont send & Report" when click dont send the msn just shut down and...
Assuming the operating system you use is windows xp and if it is, try
going to Add or remove programs by clicking on start- control panel- and then add remove programs. And on the left hand side, the third
option you will see is ADD REMOVE WINDOWS COMPONENTS, click
on it and then uncheck the msn check box and proceed by clicking
next and then finish it and RESTART your machine. Once restarted, go
back to add remove programs and then click on windows components
and check the box for msn messenger as it was before and complete
the task by clicking next and then see if messenger works fine.
Please reply back if it worked.
Regards,
Yateesh Varma.
Aug 01, 2010 | Computers & Internet
The handset is unable to receive calls via Skype,nor am I able to make calls via Skype Handset says Disconnected
If you use windows vista, and installed windows live messenger, you wil have alway`s this problem, solution is, dont let msn start up with your pc.
The best way, under software remove msn messenger, and install again en dont let it start wen your pc start up. skype and msn dont working together.
i hope your problem is solved
Feb 08, 2010 | Logitech Cordless Internet Handset Phone
Need to know how to unblock sites and msn from school laptop
i agree u need to be admin on ur laptop to unblock web sites or why dont u try msn weblive thats if u can surf the net that is
Oct 08, 2009 | Lenovo IdeaPad S10-1211U Netbook
Msn key ports will not fix!
Dear Friend,
First of all, always check the status of your web browser before signing in to windows hotmail messenger.That means that if you try to sing in, be sure that work offline mode in your browser is not checked.Secondly, have you run the MSN MESSENGER port configuration?Third and most important, have you opened the ports in your firewall?
Here is the list of thee ports that MSN Messenger uses:
1366 MSN Messenger
1367 MSN Messenger
1838 : TCP MSN Messenger (Gamevoice)
1863 : TCP/UDP MSN Messenger primary (incoming)
5190 : UDP MSN Messenger (incoming)
6891 : TCP MSN Messenger Filetransfer (incoming) - ports 6891 - 6900, one port per file transfer
6901 : TCP/UDP MSN Messenger Voice Telephony (incoming)
5004 : UDP MSN Messenger, ports 5004-65535. Used for AUDIO and VIDEO. Caution: securty risc! Do not open ALL these ports!
5004 : UDP MSN messenger (dynamically uses a port in this range 5004 – 65535 - requires uPNP in your NAT router and/or firewall). Used for AUDIO and VIDEO. See Microsoft website for details....
Good Luck!
Jun 22, 2009 | U.S. Robotics (USR8200USR8800KIT)
I CANT SIGN IN TO MSN MESSENGER
please update this software then is working proply
Jun 05, 2009 | Computers & Internet
Msn not receiving messages
I might advised you try reinstalling the MSN on your computer. It might the main problem is on the software that was been install before.
Note: If the Internet is working properly then if you can surf to the Internet. It means that the connection is working properly. Did you check if some of the messenger is working?
Apr 07, 2009 | Belkin (F5D8231-4) Wireless Router...
I want to make a Skype video call and there's no icon
yeah cameras need to be setup for each messenging service
so i'm glad you solved it
Jan 24, 2009 | Philips SPC610NC Webcam
I can't get my camera to work with my messenger program, can you help (AOL, Yahoo, MSN)? pls,help me to use my pc camera.i dont know how to open ok?
May 23, 2008 | Intel Easy PC Camera Webcam
Logitech mircrophone
It may be that this person is "messing around" with you, or their speakers are rigged, from my experince, it sounds like your headset is perfectly fine, or your headset microphone switch was toggled on "Off" Msn is just a instant messaging chat, shouldn't have anything to do with your headset.
Nov 29, 2007 | Logitech QuickCam Express Web Camera
Logitech QuickCam® Chat Web Cam Logo
42 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
