Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink system failure oxc18a0001 /c5180 all in one ink jet printer
  • HP Master
  • 1,684 Answers
This is a common problem, it is caused by air in the ink feed tubes. This happens if you allow your printer ink to fully run out and the unit sucks air or you use a poorly filled refill cartridge that has air bubbles. To clear the error you will need to do a purge on the system. The procedure takes about 10 minutes to complete. We have a step by step guide to this at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on May 28, 2010
What to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
May 01, 2010 | HP Photosmart C6280 Printer
HP Photosmart All in One error message Ink System failure -Oxc18a0001
There are N no of steps to be done so i am pasting the HP URL ,please follow it and u will get to some kind of solution in the end or u might have to replace the print head .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&cc=us&lc=en&dlc=en&product=3560280
All the Best
Feb 17, 2010 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
HP Photosmart D7360 - Oxc18a0001 Ink System Failure
please reinstall the drivers
thanks for your question
May 20, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Dec 04, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. Please let me know if the issue is not resolve so that i can check for a possible solution for that. Thank you so much. adonscott
Jul 01, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
571 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
