Question about Samsung SCH-u740 Cellular Phone
The right arrow key seems to be stuck permenantly. May have been damaged by water. Any way to fix this?
    President:
  • 1,469 Answers
Hi, did the phone fall into water?if it did, that might be the cause of it not responding.
How to fix it, you will need to service the phone so that the water can go off the phone cause some water might still be inside.
On the other hand, it also might be caused by the flex that connects the board to the screen board that makes the screen display. After servicing it you can also check the flex, it might need replacement.
Hope it helps.
Await your comment take care.
Posted on May 27, 2010
Motorola Razr flip phone stuck on contacts, right arrow key won't work. I turned phone off & removed battery & still won't work
Hi Anne,
In that case you will need to perform an FDR (Factory Data Reset), How do reset my DROID RAZR here you will find the steps to do that.
Regards,
Maya
Motorola Support
Jul 17, 2016 | Motorola Mobility Lot Of 3 Razr V3c V3m...
I have a samsung J700 and almost everybutton has stopped working, I would rather not go to the shop I got i from because i need a quick fix that i can do at home
Normally this happens when one or more keys on your phone are stuck are permanently pressed so you can not use any other key as well.
Please check all keys individually specially side volume or camera keys. If any key is stuck, then you should try to release it by pressing it few time.
I have seen same problem on many water damaged phone as well. if your phone happen to be water damage then cell repairing shop is best option.
Aug 25, 2011 | Samsung J700 Cellular Phone
I have bought a new lg gu220 mobile handset. but it has a problem with keypad. down arrow key doesn't work properly. So I want to solve this problem. Can anyone help me to solve this problem?
That seems to be a defect on that unit I suggest you have it returned and replaced right away having it repaired may fix the problem but may occur again if you have it replaced with one that does not have a defective arrow key. trying to repair the arrow key may make the damage bigger having it replaced will save you more time from doing repairs than having to repair it over and over again till it breaks.
Aug 24, 2011 | Computers & Internet
Knocking in front end when steering
my 05 silverado does the same thing it seems to be a common problem in the later series i found that having the steering shaft repact helps for a while but isn't a permenant fix. My chevy dealer said that GM was looking into a more permenant solution
Dec 21, 2010 | 2005 Chevrolet Silverado 1500 2WD
The fn key seems to be stuck on in order to get regular results, example f5 refresh, I have to press fn-f5, otherwise I get the below results abcdefghijklmnopqrstuvwxyz normal esc ok f1 monitor options...
Boot To BIOS and ensure you reset factory Defaults.
If no change try this:
http://www.fixya.com/support/r4510515-when_try_type_ampersand_get_quotation
Oct 05, 2010 | Dell Inspiron 1501 Notebook
Sony ericsson w580i water damaged
To solve your problem, Go to the calls menu and turn virbration 'Off'. If this doesnt fix the problem, permenant water damage maybe the cause.
Best of luck,
Matt
Jan 28, 2009 | Sony Ericsson w580i Cellular Phone
Water spill on my AOC2216Vw LCD Monitor
Hey man, thanks for coming to me. Um yea, massaging may help but too hard will do damage since it is LCD is Liquid Crystal Display and it is fragile and easy to damage. The water should clear up in a few months, if not i would look at replacing it which can be costly. Here is a link to fix your unstuck pixels
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor]
Now im not liking that bit about how you mentioned was spreading so leave it for about two days, give the therapy for the screen a try and let me know if the laptop screen is healing. For the moment if you have one i recommend you hook up a VGA Monitor, old school stuff if you can and give the LCD a rest. I will post as a solution but comment back and i will keep helping you as much as you need it.
Dec 21, 2008 | Computers & Internet
Change Kenmore fridge water filter due to slow water dispenser
what you want to look for on the filter is an arrow turn the arrow left and then pull down
Dec 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Won't print
if your computer is in a foreign language - and you cannot understand the prompts. try the following.
1 press the setup button
2 press the right arrow key once
3 press the down arrow key twice
4 press the right arrow key twice
that should put you on the languages, scroll through the options until you find English (or your preferred language) and press the right arrow key twice once more - that should reset the language for you
Dec 04, 2007 | Epson ACULASER CX11NF All-In-One Printer
Olympus Stylus 410
try to clean the pad using water damped cotton if you are techie, professional fix is needed if you're not.
Sep 07, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Samsung SCH-u740 Cellular Phone Logo
90 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
