Question about Dell Inspiron 1525 Notebook
Alt-code stuck on
Apparently there is a problem with my keyboard. The alt-codes for 3,6, and 9 are all that will print from my 10 keypad. So if I try to type 3,6,9 it comes back as ♥,♠,9\.
How do I restore my 10 key to normal?
    Sergeant:
    Champion:
  • 256 Answers
Try if in safe mode it will still have the same problem. If yes, then you may need to clean and replace your keyboard, but if not, then you need to reinstall your operating system. Be sure to back up your files first before doing that.
Posted on May 27, 2010
One Key, the Scandinavian o with a slash, is very slow after installing Windows 10
Are you talking about this ?. If so a trick to input it is to hold down the ALT key and press 149 on the numeric keypad. You can input all sorts of symbols, check out this list.
http://www.alt-codes.net/
May 01, 2016 | Microsoft New 200 Keyboard Wired Black Usb...
How do i access the characters/symbols
you need to press alt and insert ascii char code for the marks.
Oct 17, 2008 | GE USB Retractable Number Pad HO98462
Want to make a degree symbol
with num lock on using the right keypad only type alt + 176
I leave a notepad of characters that i can copy and paste from to be faster. To do any alt code google alt codes
Nov 26, 2013 | Dell 0Y3740 Keyboard
Number pad does not work
  1. Find Alt code.
    Numeric Alt codes for symbols are listed in Alt codes list. Check for Alt code of symbol you want to input.
  2. Enable Num Lk.
    You may need to simultaneously press ["FN" and "Scr Lk"] keys. That's the combination for "Num Lock" on some laptops. Look at the picture - the "Num Lk"/"Scr Lk" button is highlighted there.
  3. Hold down "Alt" key.
    Some laptops require you to hold both "Alt" and "FN" keys.
  4. Input Alt code of symbol on Keypad.
    Do this while holding "Alt" button pressed. Type Alt code on your laptop's numeric keypad. It's highlighted on the picture.
  5. Release all the keys.
    After you release all the keys alt symbol should be entered. If all this stuff didn't work - check if you have really enabled the "Num Lock" first. Remember that green indicator should shine near the lock symbol on your laptop's keyboard. If that wasn't the case - try simultaneously holding "FN" and "Alt" keys instead of just "Alt". That just might work.
Feb 15, 2012 | Toshiba Satellite P105-S9722 Notebook
How do I get swedish letters on an asus keyboard?
You get special characters by using alt codes. That is, you press and hold the "alt" key while entering a 4-digit code using the numeric keypad (or, on a laptop, the keys that serve as a numeric keypad). When you release the alt key the special character appears at the cursor location. This page lists the characters and corresponding code.
If you are using an application like Microsoft Word, there may be an "insert special character" command available. Then you can pick the character from a table instead.
Mar 04, 2011 | Computers & Internet
Where is the "tm" symbol
There is no "tm" symbol key on a keyboard, you need to enter an ALT key to type the trademark symbol.
Hold down the "ALT" key while typing 0153 and it will enter this: ™ when you release the ALT key
Mar 04, 2011 | ASUS Eee 4G Notebook
Secret keypad letters in computer
hi
Click on a text box or open a text document.
  • 2 Press the "Num Lock" key to activate your keyboard's numeric keypad.
  • 3 Press and hold the "Alt" key.
  • 4 Enter the numeric code on the number pad. Press "1" to create a "smiley face." Display a musical note by pressing "14". To make a heart symbol, press "3".
  • 5 Release the "Alt" key after entering each numeric code. The symbol will appear.
  • Jan 15, 2011 | Computers & Internet
    Cant get the at button to work even by pressing shift or not,every other key function works.
    You may have a bad key, or a key with something under it.
    Try this:
    Turn the netbook upside down so that the keysj face the floor.
    Bang on the back side that way you would to burp a baby.
    Then, take a vacuum cleaner and **** out the spaces between the keys.
    If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
    1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
    2. Depress the Alt key.
    3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
    4. Release the Alt key, and the character will appear.
    5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
    http://www.tedmontgomery.com/tutorial/altchrc.html
    Nov 13, 2009 | Acer Aspire One AOA110-1113 Netbook
    ALT Codes
    I'm a little late to the game, but...
    I share James's frustration. Seems like a dumb thing for Dell to economize on. Here's my workaround, for what it's worth.
    1. Open the Windows on-screen keyboard (osk.exe). And, for later ease of use, pin it to your taskbar. (Detailed instructions: click on the Windows start button, type osk.exe in the search box, right-click on the program, select Pin to Taskbar.)
    2. On the virtual keyboard, open Options and select "Turn on the numeric keypad." After saving the setting, press the NumLock button.
    3. Here's the tricky bit: press and hold Alt on your physical keyboard, and then press and hold Fn, again on your physical keyboard. You're holding them both down, right? Keep doing it. Now enter your four-digit code on the virtual (on-screen) keyboard. Release the physical keys. You should have your special character.
    Hope it works for you.
    Jan 21, 2009 | Dell Inspiron Mini 9 Notebook
    Working with alt spanish codes
    Alt Codes for typing Spanish characters:Here are the codes for Spanish Accents: Capitals á ALT+0193 é ALT+0201 í ALT+0205 ó ALT+0211 ú ALT+0218 ñ ALT+0209 ü ALT+0220
    Lowercase á ALT+0225 é ALT+0233 í ALT+0237 ó ALT+0243 ú ALT+0250 ñ ALT+0241 ü ALT+0252 Punctuation ¿ ALT+0191 ¡ ALT+0161 « ALT+0171 (Left Angle Quote) » ALT+0187 (Right Angle Quote) € ALT+0128 Buenas Suerte,
    Jose Diaz
    Please rate this.
    Nov 21, 2008 | Gateway MX7118 Notebook
    Dell Inspiron 1525 Notebook Logo
    67 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
