Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
FM Transmitter Problem
The FM Transmitter sends a carrier signal, but no audible signal. Change frequency, and FM receiver need to change, too -- okay. Is there a switch (S/W) to enable and disable FM transmitter?
  • 2 more comments
  • LarryIEP Apr 08, 2008
    I read the manual and see if I plugged in a headphone in the jack, the FM transmitter is automatical turned off. I have never plugged a plug in the jack.
    I believe so. The sbattery level ymbol displays "+" and it worrks without base station.
    When I do engage the jack, the carrier drops out indicating a switching action. When I say carrier, the FM radio (on the selected frequency)has a dead silence response, but no audible sound -- music/voice.
    I have the origianl User Manual. Thanks for the link, it did have a manual for the next version of my xm2go portable unit which the INO model has a FM transmitter mode that you can manually turn on and off the FM transmitter in addition to phone jack automatic operation. My unit does not have the manual feature.
    Genius:
  • 1,665 Answers
Are you sure battery is full?
Posted on Apr 08, 2008
  • Pioneer Master
  • 19,396 Answers
The jack may be defective
  • Ginko
    Ginko Apr 08, 2008
    The jack may be defective, try plugging in and out a headfone set and see if it unlocks.
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory » FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
Wireless mic not sending signal
need more information.
what model?
handheld or beltpack? microphone or instrument?
check transmitter and receiver are set to same frequency.
does a different transmitter work with the receiver?
does the receiver show the transmitter is functioning (ie receiving rf) but not receiving audio signal (af)?
Nov 07, 2013 | Sennheiser Audio Players & Recorders
Unit is an AKG SR40 Dual Pro Wireless receiver, PT 40 transmitter. 662.3Mhz operating frequency. The right side channel is hypersensitive and indicates that it is picking up a signal when the transmitter...
I would suggest that you change your operating frequency. The antenna being removed suggests that the receiver is picking up interference on that frequency. This frequency is in the UHF TV band, and although analog TV no longer exists, digital TV still uses some of the frequencies.
Nov 04, 2017 | AKG Radio Communications
FM Transmitter does not connect to car radio, have FX signal and Line out works.
Car cradle works "wirelessly" with Car Radio (inherent design of unit). Place Unit in Cradle; connect Cradle to Auto Power Source, and SkyFi3 should power on. Press Menu to Get FM Radio station channels; select a lower station Channel Frequency i.e. 88.3 or any vacant channel number and the signal should transfer to your Radio speakers automatically. You can change Station frequencies as often as you need to do so--for example if traveling through different broadcast areas, some channels frequencies are clearer than others. Good luck.
Jul 19, 2010 | Delphi SKYFi3 XM Radio Receiver
My Santo NVM-4070 doesn't seem to have the audible directions.
Make sure the FM transmitter isn't on ..if it is you'll need to shut it off or tune your radio to whatever freak it's set to
Apr 23, 2009 | Sanyo EasyStreet NVM4070 GPS Receiver
How to set up fm transmitter for sanyo gps nvn-4370
At the main menu press settings
press FM Transmitter
Turn transmitter on by pressing off. Will change to On
Press the Frequency button. Than change the frequency to one that doesnt have a radio station.
All sounds from the GPS will now be transmitted to the frequency set. Make sure your FM radio is set to the same frequency.
With my one vehicle this option does not work very well & is full of static because my radio entenna is at the rear of the car. The GPS only transmits a couple of feet.
Dec 27, 2008 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Hands free calling and FM transmitter
Old post, but here we go.
1: Update to latest firmware from tomtom, for Gox20/x30 that is 8.351
2: Make an silent mp3 file and put that onto device
3: Play silent mp3 in loop
4: Send nav instructions over fm to radio... et voila!
Jul 20, 2008 | Tomtom GO 720 GPS Receiver
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
498 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
