Question about Minn Kota Boating
With a new Minnkota Endura for the grankids, I'm looking for extension wiring to the battery in front of the mid seat of a 14' flatbottom, and the 60 A fuse holder. Does the company sell these items?JIM
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
You can buy a universal extension set from a boat supply store and some autopart stores. the fuse and holder would have to be installed separately. sometimes this is not recommended by some manufacturers though.make sure you use the proper guage wiring to prevent the wiring from heating up. also call the 800 number on the motor to see if the company offers a manufacturer approved kit. good luck.
Posted on May 31, 2010
Parts list for a Minnkota Endura 55 Model 1352517
Request the parts list directly from Minn Kota.
Jun 17, 2017 | Boating
Minnkota endura c-50 shear pin size
You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
Trolling Motor Replacement Props Minn Kota Motors
You will find prop nut kits here just follow the link.
Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
Minn kits endura owners manual needed
Go to minnkota.Com you can download a manual in PDF format to your pc.
Sep 16, 2014 | Boating
I want to mount my endurac2 on the back of my boat but the handle an the prop are in the same direction is it possible to turn one or the other
Not entirely sure with your model but it is possible to take the head off (where the handle is) and spin that 180 degrees. You may also check an aftermarket prop that has opposite blade direction. So where normally it's on the front of the boat, pulling through water it's now pushing the water when moving to back of boat. Shouldn't be hard to locate
Apr 04, 2013 | Minn Kota MinnKota ENDURA C2 30 30"...
My minn kota endura 55 is three years old is making a grinding noise when in operation..
I had this problem with my MinnKota Endura 35. The gear teeth that turn the prop are off center and need to be realigned. You need to take it to a service depot as trying to open the casing yourself may do more damage. Plus when it it put back together you need to ensure that it is water tight again.
Cost me around $85 at the local marine mechanic...
May 22, 2011 | Minn Kota Endura 55 42 In Trolling Motor...
Where is the battery in a 2008 buick enclave?
it may be under the back seat,,buick notorious with that..
Jan 20, 2011 | 2008 Buick Enclave
Stock audio wiring diagram
Car Radio Battery Constant 12v+ Wire: Green
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Driver Seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Tweeter Speaker Positive Wire (+): Blue
Left Front Tweeter Speaker Negative Wire (-): Brown/Red
Left Front Mid Speaker Positive Wire (+): Black
Left Front Mid Speaker Negative Wire (-): White
Left Front Low Speaker Positive Wire (+): Yellow
Left Front Low Speaker Negative Wire (-): Blue
Right Front Tweeter Speaker Positive Wire (+): Blue/Orange
Right Front Tweeter Speaker Negative Wire (-): Green/Orange
Right Front Mid Speaker Positive Wire (+): Black
Right Front Mid Speaker Negative Wire (-): Brown/Red
Right Front Low Speaker Positive Wire (+): Black
Right Front Low Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Yellow
Right Rear Speaker Negative Wire (-): Blue
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 11, 2010 | 2003 Kia Sorento
How do i extend my battery cable on my minn kota 36 endura
You can purchase a battery extender cable. Depending on how far you need to go, you can buy them in various lengths. I've done the same and bought a 15' extension (always buy a few more feet than you think you need). Many places carry this. I bought mine at BassProShops for $25.00 and it comes with fuses which help to make sure you never fry your motor or battery!
Aug 31, 2009 | Minn Kota Endura 30 Freshwater Transom...
MinnKota Endura 50 Runs only in high speed in forward and reverse
the coil pack is likely bad especially since you changed the switch. call minkota and get the bench tast info (very simple) and then order and replace the coil pack about 26 dollars. be very careful how you put the magnet assembly back together and mark the position of the case on the outside before disassembly. order a new seal kit and use locktite on the shaft again when reassemling to seal the shaft tube for water. dont run motor uout of the water much as it uses the water to cool the shaft and you can damage the seals. good luck.
Jun 18, 2009 | Minn Kota Endura 30 Freshwater Transom...
Boating Logo
74 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
