Question about Electronics - Others
Do pop up campers have batteries for their electrical system?
  • 1,383 Answers
YES MOST DO TO RUN LIGHTS. YOU NEED TO SNOOP AROUND YOUR CAMPER TO SEE IF IT HAS A PLACE FOR A BATTERY. SHOULD BE ON THE OUTSIDE OF THE CAMPER.. NOT GOOD TO HAVE IT INSIDE OF CAMPER UNLESS IT A SEALED BATTERY, BATTERY'S LIKE A CAR BATTER GIVE OF HYDROGEN GAS AND CAN EXPLODE VIOLENTLY SO IF YOU ARE THINKING ABOUT ADDNG A BATTERY PUT IT ON THE FRONT HITCH ASSEMBLY AND USE A FUSE THAT MATCH THE SIZE WIRE AND LOAD.. YOUR LOCAL AUTO PARTS STORE CAN HELP YOU WITH ALL THE THINGS NEEDED RIGHT DOWN TO THE 12V FLOAT CHARGER OR MAYBE EVEN SOLAR ! GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
Posted on May 28, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
  • Chornic solar charger is designed to the highest technical specifications and standards ,It will supply years of maintenance free use.
  • * User's Manual,14 watts foldable USB Port solar charger.
Chornic 14W Foldable Solar Charger with 2 Port USB Charger Build with High...
Posted on Jan 04, 2017
I have a coleman cheyenne 2000 pop up camper and none of the lights will turn on to include the carbon monoxide alarm. All of the outlets work fine. We checked the fuzes and flipped the switch. We also...
when towing my camper it seems my running lights do not stay on andmy brake lights and turn signals do not work properly. I can giggle the harness wires and everything works.
Jul 08, 2010 | Camco Battery Fridge Refridgerator Alarm...
How can i get electricity inside my slide in truck camper
carry an extra altenator just in case for your truck
Mar 12, 2010 | 2003 Chevrolet Silverado 2500HD
RV Auxillary battery overcharges
cut a switch between this battery and the charge system
Oct 10, 2009 | 1991 Chevrolet C3500
Propane refrigerator?
Yes , when the refer needs to cool it will fire up only with the LP. In the electric selection it will work the same way. Do not fret , it is working ok.
Aug 31, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Water problems on 85 rockwood pop up
There is generally a water pump fitted. In the early days of campers the water had to be pumped manually by either a foot or a hand pump and later people grew lazy and so electric pumps were fitted. At first these were controlled by a switch or button close by each faucet and needed to be held pushed in for water to flow - for obvious reasons the flow stopped when the button was released.
Later people grew impatient as well as lazy and also tended to be slightly wealthier and liked to take a shower so the system was automated. The electric pump was integrated with a water pressure switch so when a faucet is turned on the water pressure fell and turned on the pump and when the faucet was turned off a significant pressure would build in the pipework, sufficient to cause the pressure switch to turn off the pump.
The scope of the equipment varies a great deal depending on the amount of water carried, the size of the camper, the hot water system and the price range and could be anything from a single submerged pump to a multipump system to provide a luxury shower.
I suggest you obtain a manual or owner's handbook in order to discover the equipment fitted to your camper and how to operate/troubleshoot it. Such information is of particular importance if the camper will encounter freezing temperatures during the winter lay over. Failure to winterise properly can cause a great deal of expensive damage.
Aug 19, 2017 | Coleman Campers Grill
We have a 2007 Palamino Yearling Model 4101 Pop-Up Camper and recently it was vandalized and the wires from the camper to my vehicle were cut and destroyed so we have to replace the vehicle end plug to the...
Is this a six way plug (six round holes)? If there are six wires coming from the trailer, then the color code should be as follows:
White - Ground
Brown - Tail Lights
Yellow - Left Turn
Red - Stop
Green - Right Turn
Blue - Auxiliary Circuit (Battery Charge, Electric Brakes, etc...)
If you open the plug up that was cut, it is labeled as to which goes where.
TM = Tail Lights
RT = Right Turn
LT = Left Turn
S = Stop
G = Ground
Center = Auxiliary
Jun 27, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
2001 Dodge Dakota Trailer Brake Wiring
Call dealer & ask them to run your vin# to see if it came with towing package. They shouldn't mind. If not, you'll have to wire it in yourself.
Jun 05, 2009 | 2001 Dodge Dakota
Auxiliary battery use
The extra battery is there because of the glow plugs and intake heater of the duramax. During cold weather both of these systems draw high amperage from the batteries. A single battery will function, but not as well as a pair.
Apr 08, 2009 | 2005 GMC Sierra 2500HD 4WD
Electronics - Others Logo
966 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
