Question about Dayton Permanent Split Capacitor Motor Fan
I have a Dayton 36'' chicken house fan with 115/230 there I found 6 wires, orange &black wire nutted together . white,yellow hooked to electic(White wire from electic). purple hooked to (black electic.) green to ground. If you can,Please tell me,how should the wires go together to run the fan with 115 volt? as is when the fan is ran it heats up and kicks off until cooled. Thanks you Tom
  • 1,368 Answers
GRAINGER.COM THEY HAVE A TECH LINE, BUT ON THE MOTOR LABEL IT SHOULD HAVE THE WIRING DIAGRAM .. GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
Posted on May 28, 2010
How to bypass a Concept II fan receiver?
SURE you want to do this? A REPLACEMENT Receiver is just $36 bux...
Minka Aire P001021500S Receiver 6 5Uf Dl
[Brand & Part #: Minka Aire P001021500S SKU #: minp001021500s UPC #: 706411042003]
This APPEARS to be your manual:
https://www.1800lighting.com/documentation/Installation/Minka-Aire-Ceiling-Fans/F518.pdf
>>> See Figure 4 <<<
The big question IS ~ how will you switch the fan and lights after your mod?
*** DO THIS AT YOUR OWN RISK! POWER OFF FIRST ~ have a DEPENDABLE/BRIGHT flashlight ready!! ***
MARK BOTH ORANGE WIRES at "both ends" with small strips of masking tape: "1" and "2"... )so you should end up with 4 strips). #1 at the Receiver and then #1 at the fan. #2 at the Receiver and #2 at the fan.
Looking at figure 4 ~ "I" would connect WHITE to WHITE.
Then connect (two) ORANGE + BLUE + BLACK wires together... TWIST them tightly-TIGHTLY together. Now TRY a YELLOW wire nut to bond them all together... if that is not large enough use a RED wire nut.
CAREFULLY strip more insulation jacket ~ if needed... then trim to required EQUAL length.
YOU DO understand this will put your LIGHTS AND FAN into a constant ON condition? And I suspect your FAN will be at high-speed?
Anthony
Dec 20, 2017 | Dryers
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
Nov 11, 2017 | Dryers
How to wire air compressor motor to 220v
Insulate brown means cap and tape.
240Volt should not have neutral wire
http://waterheatertimer.org/Basic-house-wiring.html#basic-wire
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
240Volt coming from breaker box will have 2 hot wires... and either hot wire is same no matter wire color
http://waterheatertimer.org/Color-codewire.html#motor
Gene
Oct 07, 2014 | Hardware & Accessories
How to wire for 220 v
220 is two hots and one ground. If it were me I would leave red orange and white "together",then verify your voltage on remaining wires. 110, 110, 0. If not, youre no good. Try something different. It doesn't matter what "line" goes to what "load" just as long as one of these goes through whatever relay/switch you are using. Good Luck. Hopefully single phase. If motor runs backwards swap wires.
Mar 14, 2017 | Heating & Cooling
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
Dayton 3 speed switch 34g191 has no wires or diagram. how do I hook it up.
2a5da9a5-aac3-42c6-abd8-aafc5120b40f.jpg205419c3-0ab0-44b2-af3d-75ca1d7c5061.jpg30a6a9a2-5d9a-485b-aa23-85f37da6902a.jpgDayton fan motor 6C539A Grainger switch number 34G191. Luckly I have two fans. So when the one I went to pull out fell apart before making anything I pulled the other one apart. Okay, on the white plastic there are numbers l(1), ll(2), lll(3). Orange wire l(1), nothing in ll(2), blue wire lll(3). Now on the black plastic, the outlet wires go here: black wire L, white outlet is 180degrees (by orange wire) NEUTRAL SPLICER. Now, white wire from motor goes into the other side of the NEUTRAL SPLICER next to the black wire on the black plastic. This is just above the ll(2) on the white plastic. REMEMBER - NOTHING GOES INTO THE ll(2) ON THE WHITE PLASTIC.
May 02, 2013 | Dryers
Am installing a ceiling fan and do not have the installation instructions. The fan has a black wire (labeled Motor), a white wire (labeled Neutral) and a blue wire (labeled Light). What is the proper...
When dealing with older houses, you run into this a lot, but the somewhat newer houses will actually have the 3 wires to hook up the ceiling fans. You can still use your 2 wires, but you will have to double up the motor and light wires. Wire nut the Black and Blue wires together with your Black wire from the house, and the White wires will be tied together for your neutrals. You should also have a green ground wire also, be sure to hook that to a ground in the house too. Hope this helps!
Aug 04, 2010 | Heating & Cooling
"i'm replacing my Rheem RBGC 08KA FAU blower motor. My dayton 3lu83j 4 speed motor has white, black, red, yellow,orange, brown, and brown with stripe wires. My old westinghouse motor has only one brown...
There should be a wiring diagram on the side of the new motor.
The brown and the brown w/ white go to the new capacitor you should have bought with the motor.
The black and white go to your L1 & L2 power source. The remaining wires must be capped off.
Feb 25, 2010 | Dayton Heating & Cooling
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
I have a carrier AC model#50ee036330, the fan motor went out it was an emerson2 speed with 3wires.IMtrying to replace it with a GEMOTOR no.3586 with6 wires at 1 side and 4 on the other.6wires arered black...
jenny,White and black is high speed,wire nut the yellow and blue by themselves(2) brown wires cap.yellow brown together and orange and purple together they should be direction wires.If the fan runs backwards change them
Aug 14, 2008 | Carrier Heating & Cooling
Dayton Permanent Split Capacitor Motor Fan Logo
736 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
