Question about Yamaha RX-V2600 Receiver
When i turn up the volume on a movie the receiver turns itself off and when i turn it back on, it says ''check sp wires''. it seems to turn off when there is an especially loud part of the movie. i looked at all the wires and nothing is crossed or out of place. suggestions?
  • Yamaha Master
  • 11,800 Answers
Probably the wires are too thin, replace them with much thicker ones.
Posted on May 27, 2010
I bought a Denon AVR 791 receiver two months ago, work great, sound great with my Definitive Technology Speakers but 3 days ago while I was watching a movie on my PS3 the receiver turned off on the higher...
Clearly, it thinks you're overdriving it.
Blinking Power Indicator every 2 seconds means the internal temperature is high. (Page 76 of the manual)
Every half-second - speaker impedance too low.
Consider the load presented by the speakers and what their minimum impedance might be.
Check for loose speaker wires.
Feb 07, 2011 | Denon Audio Players & Recorders
Shuts off when turning volume up. Error message
go to a computer store and tell them to rebot your computer that what i did it worked for me it should probly work for u
Dec 18, 2009 | Yamaha HTR-5760 Receiver
My Denon AV-3801 will just turn itself off if volume is turned up. I have checked for crossed wires and such,not sure what is going on. Any answers?
Disconnect all speaker wires at the receiver, then turn it back on. Turn up the volume. If it shuts down, it needs to be serviced. If it stays on, reconnect speakers one at a time and turn on the receiver then turn up volume. When you find the speaker that causes the receiver to shut down, disconnect the wire at the speaker and re- test. make sure wires are separated. If it shuts down, replace the wire, if it stays on, meter the speaker itself to check for a bad vioce coil. If you don't have a meter, you can take the speaker to any audio shop or Radio Shack and they will usually test it for free. Hope this helps.
Sep 27, 2009 | Denon AVR-3801 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
My reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
Mar 07, 2009 | Sony STR-DE845 Receiver
My Onkyo Receiver TX 601 is turning itself off
May not help, but I had the same thing when I turned up the volume.. off it went.. then I found my two surround sound speakers had the wires shorting. Looks like a safety switch if there is a problem. Could check if the wires are crossed, shorted, and/or thick enouch to handle the volume.. test it by just having the stereo speakers enabled. Cheers,
Jan 11, 2008 | Onkyo HTR500 Receiver
Yamaha htr5730 receiver - turns off
You may have speaker wires touching each other or a short circuit in the wire. "Check SP Wires" means to check your speaker wires.
Oct 16, 2007 | Yamaha HTR-5730 Receiver
Kenwood VR615 turns itself off at medium volumes
I also have the same problem, it is really annoying... anyone have any ideas.... please help!!
May 21, 2007 | Kenwood VR615 Receiver
"Check Speaker Wire" error on my Yamaha Receiver
found the source of the problem with "Check SP Wires"! to solve it is necessary to check each speaker connected to the device Yamaha on the rear panel (red and black) using the device for determining the number of ohms, which shall not be less than 4 ohms, in large passive speakers experienced in Amfitone AU-027, the result showed that left at 0.45 (7) ohms, and the right-hand column, as such, no.
The successful test ... and good music!
Mar 13, 2007 | Yamaha HTR-5790 Receiver
Shutting off during a loud part of a movie
Its eather a defect with the reciver top end shut down /over bias system , Or the speakers could be partially shorted, such as instead of being 8 ohms, the speakers could have a few shorted windings from a loud music event?? I would take the speakers in to be checked under load. NOT just checked for resistance.. A regular shop may not know how to do this BUT tell them you need to put the speakers under a load and then measure the resistance . GOOD LUCK
Jun 25, 2006 | Yamaha RX-V550 Receiver
Yamaha RX-V2600 Receiver Logo
214 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
