Question about Sharp VC-H965U VHS VCR
Whats the process to change RF to channel 4? - Sharp VC-H965U VHS VCR
  • 70 Answers
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
Posted on May 27, 2010
Sanyo vwm390 vcr
That might be the TV output channel. I found these instructions in a Sanyo manual:
How to set the DVD+VCR's RF output channel 1. Set the TV to the VCR channel (3 or 4) depending upon the selected channel. 2. When the DVD+VCR is turned off, press and hold CHANNEL (V/v) on the front panel for more than five seconds. It will turn itself on and "RF03" or "RF04" appears in the dis-play window. 3. Press CHANNEL (V/v) on the front panel or CH/TRK(v/V) on the remote control to change the RF output channel (CH 03 or CH 04). 4. Turn off the DVD+VCR.
It might solve the problem!
Jan 01, 2014 | Televison & Video
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
Apex digital250A digita tv converterl
The outside antenna gets threaded onto the RF connector that says antenna in. Then either connect another RF cable to the tv and select ch 3 or 4 (switch on back of box) or use the yellow,red and white cable to the tv. If you used the three cables use the remote to select the input you used. Just advance the channels until you find the picture. If you used the RF cable, just tune to channel 3 or 4 whichever you used. Now do a channel scan with the remote that came with the converter. Once that is done you will have to use that same remote to change digital channels.
Jan 01, 2014 | Apex Digital LD4088 LCD TV
Element Plasma image overlayed with ghosting
if the images of the previous channel what you are looking it is the pdp panel problem plasma display -pdp panel
Nov 05, 2013 | Element Electronics PLX4202B 42 in. Plasma...
Can you hook up a super nes without AV cords? I have 2 cords, 1 is power and 1 connects to an antenna-like input.. do you need AV cords aswell??
It is called an RF connector.Plug your cable coming into the house from outside into the RF connector,then plug the RF connector into the TV.The TV needs to be on channel 3 or 4,depending on what it is set on the console,to use the console.There should be a selector on the console back.If there is a strong broadcast on the channel you select to use,just change to the other channel.If you have the proper channel,the TV signal will go away and the game will appear.You do not need the A/V cables.
Jul 23, 2010 | Nintendo Super NES Console
Tried the RF Out setting and now Ican't reset it or even get the STB to respond to set up or anything.
If you changed the RF out channel setting on the DTV converter and now can't see the output of the converter try changing the channel on the TV set. THe DTV converter boxes are designed to output either RF channel 3 or RF channel 4. If you were on channel 3 and changed the converter output to channel 4, you will have to change the TV channel to channel 4 to see it again.
Hope this helps.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
My nintendo 64 channel is not 3/4 ----what is it then?
Are you using the a/v cable from the N64 to the tv? The red and yellow cables?
If so then you need to change your TV to one of the video channels like video 1, video 2, video 3, it would depend on what input you have your N64 hooked up to. if your using an rf connector then make sure you are using channel 3 and you might have to make sure on the rf connector that its also set to 3.
May 04, 2009 | Nintendo 64 Console
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
Plays on wrong channel
ok i downloaded and read your DVR-1000 manual , this is what you will do .
While the DVD+VCR is turned off, press and hold CHANNEL (up/down) button on the front panel for about five seconds.
The unit will turn itself on and “RF 03” or “RF 04” appears on
the front panel display
Use CH ( up / down ) button on the front panel or CH ( up / down ) button on the remote control to change the RF output
Turn the DVD+VCR off and then on
Set the TV to channel 3 or 4 depending on the RF
output channel you selected.
Now you can watch the DVD+VCR playback on CH3
or CH4 of your TV
PS , you should see a child lock button on the remote , if you press that button , you will disable front panel button controls so kids can't change anything , press it again to unlock that feature , it might come in handy.
Thanks for using Fix Ya .
J5
Jan 23, 2009 | GoVideo Go Video DVD/VCR Combo
Trying to watch vcr on channel 4, but the vcr is set to channel 3
You can watch the TV programs
with the tuner of the unit. (Usually
channel 3 or 4 of the TV is
available for the RF converter
setting.) Be sure to connect the
unit to a TV using the RF cable.
Select channel 3 on your TV.
Press [VIDEO/TV] on the remote
control.
• If noise appears, change the
RF output channel of the unit to
CH 4 by pressing [VIDEO/TV]
for 3 seconds. The RF output
channel will alternate between
CH3 and CH4
Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
Sharp VC-H965U VHS VCR Logo
463 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
