I'm trying to find a matrix printer epson rx-80 driver for a windows xp comp
    Scholar:
  • 162 Answers
The good news is, you don't need to look for drivers for this printer. It is supported by windows xp.
Just do following:
- click start - control panel - double click printers and faxes
- on the left pane, click add a printer. (don't forget to connect your printer to your pc and it should be turned off)
- the wizard will try to look for the printer and will not find any
- just click next, then next till you arrive at selection for different printer models
- just select your brand, epson on the left and the model, rx80 on the right pane.
- just follow the wizard, until it was finished.
- it may ask you to set it as default printer, but it's your option.
- now you're done, treat yourself to mcdonalds and celebrate this little things in your life :)
Posted on May 31, 2010
  • Dax Estorioso
    Dax Estorioso May 31, 2010
    I forgot, turn the printer on after this method. do some testing. It if still doesn't work, check the cables. Usually, it is the parallel cable from the printer to the computer. Just disconnect and reconnect.
    Again, if this does not work, replace your parallel cable.
    Good luck! :)
Wipro lx 540 dot matrix printer driver software for windows 7
DONT WORRY,
YOU TRY EPSON LX 300 DRIVER (IT IS ALREADY AVAILABLE IN WINDOW XP'S DRIVERS DATA)
YOUR WIPRO LX 540 PRINTER PERFECTLY WORK IN EPSON'S LX 300 DRIVER FILES
Jul 31, 2013 | Computers & Internet
I wan epson lq 580 driver for window 7 32bit
try windows xp 32bit driver
manufecturer link for further information windows xp driver will support in windows 7
tech.epson.com.au/downloads/category.asp?sCategory=Dotmatrix&id=lq580&SelOS=Y
link for download
http://tech.epson.com.au/downloads/product.asp
Sep 23, 2011 | Epson LQ 580 Matrix Printer
Don't have drivers for windows XP
Drivers for the various operaring systems are available here:
http://www.epson.co.uk/Printers-and-All-In-Ones/Dot-Matrix/Epson-LQ-300+II/Drivers-Support?supportLandingPage=true
Use the drop down menu to select your operating system. Make sure you select the correct system; Windows XP 32 bit or Windows XP 64 bit.
Aug 13, 2011 | Epson Dot Matrix LQ-300+II Printer
I WANT DRIVER FOR PRINTER PANASONIC KX-P1150 FOR WINDOWS 7
You might have to use EPSON FX Series 1(80) INBOX Driver*1
what *1 means - INBOX Driver is Printer Driver that is included in Windows 7. so all you need is to go to Control Panel - Printers and Scanners and choose EPSON FX Series 1(80) INBOX Driver as your driver fot your Panasonic printer. This advice was recommended by Panasonic, I have tried to locate the driver for Win7 but no luck I hope this works for you. Good Luck
Jun 10, 2011 | Panasonic KX-P1150 Matrix Printer
I have the matrix printer Panasonic KX-P3196 and I cannot find somewhere a driver for windows vista. Do you know if there is an alternative solution? Probably an IBM driver?
Epson drivers better bet ie rx-80 if 132 char printer.
Lot of dot matrix printers had Epson compatible mode available as they were the biggest then.
Apr 26, 2010 | Panasonic KX-P3196 Matrix Printer
I am trying to instal a driver for an epson lx300 dot matrix printer on a windows xp operating system but can't seem to find the right driver. Anyone got any ideas?
1) Go to below website and download the latest drivers from there.
http://www.epson.com.sg/epson/drivers/driver_download.htm?mode=3&catid=2&productModel=2&catid=&pid=985&ad=1&downloadType=Windows
2) Before you Install new Drivers please remove old drivers for the printer and give a reboot to the computer.
3) After giving a reboot to the computer install the latest drivers those have been downloaded and then give a reboot to your computer again.
This will work in a perfect manner. Best of luck.
Feb 25, 2010 | Office Equipment & Supplies
I need to install printer Epson LQ 300 dot matrix on a laptop with OP Vista.the curent driver is not working can anyone please help me to resolve this issue.send me on elias.ishak@gmail.com
You have a few options. One is to try a differant driver supplied by mictosoft. These are the ones that you see listed whn you run the add printer whizard. The generic default for all dot matrix printers (regardless of brand) is the MX-80. Thats is a narrow lower quality printer. You coudl try one of the drivers from epson but there isn't any specific Vista printer so you can try the xp driver. http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14311&prodoid=8241&infoType=Downloads&platform=Windows
Nov 04, 2009 | Epson LX-300 Matrix Printer
Printer install
Try to install epson 1050 printer driver in windows drivers.
Feb 26, 2008 | Epson LQ1170 Matrix Printer
Windows xp printer install
Hi, Have you tried the Epson driver "ep10759.exe"? It is available at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14250&prodoid=8192&infoType=Downloads&platform=Windows It this still doesn't workout for you, pls post back as to how you connect the 810 to your PC (USB or LPT/Parallel), Good luck and kind regards.
Oct 08, 2007 | Epson LX-300 Matrix Printer
Computers & Internet Logo
David Payne
David Payne
