Question about Refrigerators
I need to find a circuit control board for a 3 door wine cooler. Part number either HJT PCB 70913K2 or maybe OV49 E24025 S-E4 I'm not sure what brand name it is
    President:
  • 2,468 Answers
Find a model number and a make and i more than likely carry the part
Posted on May 27, 2010
How do I get a PCB70323E1
Have you looked at the back of the board for burn outs?
Jan 17, 2015 | Emerson Fr24sl 8 Bottles Wine Cooler With...
Danby wine cooler refrigerator temperature control won't work
Without more details on what you're observing, I can't say for sure what could be wrong. I can just tell you that I had problems with the temperature not controlling properly, and the set temperature seeming to vary on its own. It turned out that one of the 5-wire bundles that plugs into the back of the controller (PCB) was snugly pressed into the pins on the back of the circuit board, which was causing shorts in the control circuits. I inserted a piece of heavy cardboard in between them to ensure separation, and presto, my machine now works correctly again. So before buying parts, I would suggest you examine the control board and wiring for possible problems like this.
Sep 02, 2014 | Furniture
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
Need to order PCB for Magic Chef wine cooler MCWC44DZ
Go to this page it will take you to a "dropdown" menu. Go to your model number and there will be 2 different PCBs in each category. One is for the door the other is the main. make sure you get the right one....match up the numbers you mentioned 155TD in yours which is the "pren" version of the 2 choices. Hope this helps you! http://mcappliance.com/partorder.aspx
J
Jun 27, 2012 | Magic Chef MCWC44DZ Wine Cooler
I have a e4 code on my wine cooler
I am sorry to hear regarding the trouble. This is a common problem on this unit. E4 refers to a faulty control board failure. Unplug the unit for few minutes, say 15 minutes and then turn it on. If this would not reset the error code, the only solution is to replace the board.
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 30, 2011 | Danby DWC283BLS Wine Cooler
Wine cooler Doesn't work
I had the same issue on a Whynter WC28S SNO 28 Bottle Wine Cooler, it even seems like most of the thermoelectric wine coolers, fridges, and such have the same boards by hanny. For cross refference parts I used NTE because Fry's Electronics had them.
Switching transistors - NTE51
1N 4007 - NTE125
Silicon Dual Power Rectifier - NTE6090
Also I have a venotemp wine cooler that has pretty much the same board, with the same plugs for fans, light, control panal, and cooler fan for $45 shipped at their site under replacement parts. Hope this helps people looking for info on this. Also research Switching Power Supply issues for information.
Oct 26, 2009 | Refrigerators
AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Jun 04, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Jul 13, 2008 | Danby DWC513BLS Wine Cooler
Danbysilhoutte
sounds like you need to replace the control board, i believe there may be two parts here - if there are, try replacing the power control board before trying the electronic control piece... this is the board that has the low and high voltage circuits and relays.
May 18, 2008 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
