Question about Fuji FinePix S3000 Digital Camera
Doesn't download with usb cable anymore - Fuji FinePix S3000 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Dec 30, 2012
My toshiba external harddrive usb 3.0 won't work
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps you
Sep 18, 2011 | Toshiba Notebooks Canvio E05a075cau3xw 750...
Tip
Connecting an Eclipse MP3 Player to a Computer
Many people have found that their computers do not recognize the Eclipse mp3 Player, even after connecting with a USB cable. I had the same problem but discovered that the problem lies with the cables themselves. I have several USB 2.0 5-position cables that fit the Eclipse USB port perfectly, but only ONE of them actually works - the cable that came with the player itself. If you've lost this cable, you may be in trouble.
Attached is a screen-grab of the type of USB plug and port involved. You don't see them around very much anymore, and I have no further advice if your player doesn't have a USB port of this shape.
on Feb 01, 2015 | Eclipse Audio Players & Recorders
My camera doesn't register on the computer via the USB cable cord. I turn on the camera and nothing. I can't use the USB cable with my camera anymore. Any way to correct this?
Make sure it's not appearing in "my computer" as a removable drive. If it isn't, you can try using a card reader for downloads. typrice_204.jpg
Jun 29, 2011 | Cameras
Hi my blue light for the external hardrive turns on all the time but my computer just wont detect it \r\ndoes this mean that my hardrive doesn' work anymore? is there anyway i can all my files bac? thank...
If it used to read it, but doesnt anymore, could be a sign of a hardware failure. If another computer reads it, then it is probably a driver issue. Try to turn the power on, then insert the USB cable into the computer.
May 03, 2011 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
It says that my absorber is full.what must I do?
Hi there
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
All the Best Pineworks
Mar 11, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip2000, waste ink absorber is full
Hi there
Mar 10, 2010 | Canon PIXMA iP2000 InkJet Printer
Hi, I have an external disk connected to an usb port. Sometimes my computer stop to recognize the connection and my external disk doesn´t works anymore, until the next reboot. What can I do to resolve...
The only other solution other than rebooting is to remove the cable from the usb port and reinsert it. Sometimes the computer will recognize the drive and it will work properly.
Aug 13, 2009 | Microsoft Windows XP Professional SP3 Full...
I keep getting message " waste ink absorber is almost full" where is this and how do I empty it?
I have checked your post and have found this problem for a similar canon that might help you:
"Here's the steps for reseting "Waste Ink Full" problem
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN"
Jun 27, 2009 | Canon PIXMA iP1600 Printer
Fuji FinePix S3000 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
