Question about A.O. Smith SQ1102 Pool Pump Motor
It is leaking water between the motor and the impeller, I just installed it at the end of last season and it worked fine but when we opened our pool this week and turned it on, it started leaking. I tightened the bolts, but no help there. I just thought i would ask before i start tearing it apart.
    Scholar:
  • 54 Answers
Sounds like the seal is leaking, but in cold climates I'v seen the cases cracked from freezing. How much water is leaking and does the leaking get worse when the pump is running?
Posted on May 27, 2010
Lots of silocone blue stuff or **** load of j.b. weld or replace the rubber rings[gasgets] be sure to use a good sealent you will have to remove the 4 bolts and the propeller inside to get to the smaller O ring as well [is only appox 2-4 inch round] depending on h.p
Posted on Jul 26, 2010
How to clean debris from impeller? Pump is not drawing water from the skimmer/pool .... I'm hoping the impeller is clogged and not something more serious like a shot motor.
There are normally 4 to 6 bolts around the outside connecting the wet end from the dry end. Undo those bolts and the front of pump should come away. Then you should be able to see impeller. Using a piece of wire poke it through each slot of the impeller to clear the blockage. Then put back together again. Remember to prime the pump
Jan 30, 2017 | Pool & Spa
Pump is running but not pumping
Possible broken impeller from motors shaft, common Intex problem.
So...
As a technician of more than 30 years in the Pool/Spa Industry, And with the rise of these Quasi-Pool or Spa wannabe's, popping up everywhere, I have seen SOOOO Many frustrated customers and owners of these units, with very similar problems and non working pool and spas!
Unfortunately these Intex products are Mass Produced by the Gazillions in China, and then unleashed on the general American public? Who believe that it will work and last, but come to find that they usually don't last a season! Some die sooner, and yet some do last a little longer. AND, there are no available parts to repair! They make you buy a complete replacement control unit! So if your controller panel has a bad button, no available part, whole new control system! Heater stopped working? No available element to replace, whole new controller! Pump not pumping water or leaks - yep, No impeller or shaft seal available, Whole new pump, Etc. etc.
So many customers of mine, regret their purchase.
So...To try to help, and maybe get them back into a splashing good time or... Back in Hot Water..
I tell them ... SQUEAK! And do it loudly and often!
Maybe they will listen and OIL that Sqeak?
look here...
http://www.intexcorp.com/contacts
then if if budget allows, don't buy another Intex component, if you get no help from them, get a Real Pool Pump and if possible, mate it with a Real Pool Filter, not just toys.
Something like this...
Hayward S144T1540S Pro Series Top Mount Sand Filter 14 Inch 4 way Valve...
Jun 10, 2015 | Intex Automatic Salt Water System for ...
Century 1081 Pump
if leaking probably ruined bearings just replace whole pump
May 16, 2013 | Century New Magnetek Pool Spa Pump Motor...
Pool motor problem
If your pump is not moving water you first want to check the skimmer and pump baskets and make sure they are empty as not to restrict water flow. Next make sure your pool filter is clean. Once you have checked these, you may want to check the pump impeller. This is the part in the pump that is connected to the motor that moves the water. Impellers will clog from time to time, especially during the springtime. To inspect the impeller, you will need to open the pump, to see inside of the impeller housing or volute.
May 01, 2013 | Pool & Spa
I have- starite pump it was working fine last night but this morning there was no pressure at all i wonder if is the water tank the pump is running fine but there is no water
It sounds like you have blown your shaft-seal. When this happens the pump runs dry. If you know that you have water but it will not pump, and all the cover and housing o-rings are good, it is the shaft seal. (unless the internal impeller is just broke, but this is unlikely)
Fix: Turn off power. Remove V-clamp holding wet end together. Remove diffuser inside wet end (need flathead screwdriver).
next remove rear electrical panel on the motor. Using s 7/16" wrend, hold the end of the motor shaft by the electrical end (where you removed the cover) while turning the impeller counter clockwise (note: some impellers have an impeller screw inside which unthreads CLOCKWISE) untill impeller is off. Replace carbon shaft seal inside. Reverse and prime and then restore power and start.
Oct 20, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
Water shooting out of the pump motor shaft?
The mechanical seel is bad. These seals normally last quit a few seasons, as long as they don't freeze or allowed to run dry. You will have to disasemble the motor from the pump, and then remove the impeller from the motor. Depending on model and brand, most of these parts are plastic and one must be very careful not to break. The seal could either be purchased from a pool company or from a place like Graingers. If you don't want to do it yourself you could take your pump to a pool company or a motor repair shop.
Jul 02, 2010 | Pool & Spa
I have a hayward XP power flo motor, this season it seems to be making an extremely loud noise when I plug it in. Is there a way to fix this?
Usually, if the motor is extremely loud it is caused by a problem in the motor. It could also be caused by a bad seal but then it usually leaks from between the pump and the motor or an impeller problem. The most likely motor problem causing noise is bad bearings. These bearings are usually not worth replacing because the water that may have caused the bearings to fail have also caused corrosion on the bearing mount.
Aug 07, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
A.O. Smith SQ1102 Pool Pump Motor Logo
567 people viewed this question
Top A.O. Smith Plumbing Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Gil Shultz
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
