Unplug the refrig . Inside the refrig section , remove the 4 screws ( 2 on each side ) and
lower the panel . Disconnect the large plug and remove the panel by pulling foreward to
clear the defrost drain hole .Find a food safe caulking or odorless silicon and caulk at the
upper portion where the styrofoam meets the plastic AND on the top center of the styrofoam (
all the way around the large rectangle hole ) so that the styrofoam will seal to the top of
the refrig . When the refrig goes into defrost , the water is seeping between the refrig top
and the styrofoam , causing it to run into the refrig section . When reassembling , be sure
to plug the large plug back into the refrig .
While the panel is down , use a hose inserted into the opening of the drain hole on the rear
wall , to blow thru to remove any unseen blockage in the drain line .
