Question about Sigma DP1 Digital Camera
Dp 1 doesn´t function when the SD-card was returned to the camera
Removed the Sdcard and used a card reader for transferring the photos to my computer. Then returned the card to the cameraslot for formatting. Alas, when I turned ON the camera, the lens opened and the lamp just outside the lcd-screen (upper right-hand corner) started to blink red and green and the DP 1 didn´t function. Holding the powerbutton down for about 5 seconds turned the power off, but the lens remained in the open position. Turning the camera ON again the lens retracted, opened and stayed open but the camera still didn´t work.
Regards Leiv Guntveit
    Brigadier General:
  • 11,967 Answers
Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Posted on May 28, 2010
Why is my nikon coolpix L26 not uploading my pictures
First, use the review function to make sure your camera actually took the pictures. Assuming it did, I would remove the SD memory card from the camera and use a card reader to transfer the pictures to your computer. If your computer does not have an SD memory reader, many USB readers are available for under $20. They are USB devices and once they are attached to your computer and you insert the SD card, the computer will act as if the SD card is another external hard drive. You will be able to transfer your photo files from the SC card to a file on your hard drive via copy and paste or drag and drop. Although you can erase your card when you are done by deleting the files, it is better to put the card back in your camera and use the format function found in you camera's menus.
Jun 19, 2014 | Nikon Coolpix L26 Compact
How do I import photos from my camera?
There are two ways to import your photos.
One, your camera should have an sd card which you can eject and put into your computer. The sd card should have all your photos and videos in it. Typically the card is located near the battery and you can press down on it and it should pop out. You may also need a sd card reader or micro sd card reader if it doesn't fit in your computer.
Second, your camera should also have a usb port, whether micro or mini or whatever. It should have a port to connect to your computer through a usb cable. In this case, just connect your camera to your computer and it should show up on your computer like an extra drive where you can go in and see all your photos.
Also, the folder that holds everything is usually labed DCIM i believe.
Hope this helps.
Oct 26, 2012 | Cameras
Memory card locked
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 19, 2012 | Nikon D3000 Digital Camera
Transfer files from Toshiba Satelite L670-187 laptop to SDcard reader!
Make sure the drive for SD reader is installed.
go to my computer and see if you can see the card if you cannot see the card - right click on my computer and and choose properties next chse hardware then device see if you can see the driver for the SD card (if there is a "!" on that device driver download the driver from the internet (sd card manufacturer)
Apr 17, 2012 | Toshiba Computers & Internet
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
How do i upload pictures from my memory card to my computer without the cord
You will need an external card reader to do this. Assuming you have one on hand or have a card reader built into your computer; just take out the memory card from the camera and plug it into the external reader. Your computer will present you with options on how to transfer your photos.
Mar 05, 2011 | Nikon Coolpix L15 Digital Camera
My children gave me a digital photo frame for Christmas. I have a Nikon digital camera. I have downloaded and deleted from my camera several pictures I would like to put into my photo frame. Am I able to...
If the "camera chip" you refer to is a removable SD Memory Card you need to put that into a SD Card Slot on your computer or use an USB Card Reader device. The computer will recognize the SD Card as a Disk Drive and you can use Windows Explorer to transfer the picture files to it.
Dec 29, 2009 | Coby DP-767 7-Inch Widescreen Digital...
Nikon S51 camera. Can I transfer photos from the computer back to the camera onto an empty sd card in the camera? I accidentally erased the photos off the card when I transferred the photos to my...
That would depend on how the camera/card is connected to the computer.
If you're using the USB to connect the camera to the card, then the answer is "no." The camera functions as an expensive card reader, with "reader" being the operative word. It will not allow you to write to the card.
If you have the card plugged into a card reader connected to the computer, then the answer is "probably." Assuming the picture is as it was when transferred from the card (not edited or manipulated in any way) then you should be able to drag&drop it from the computer to the \DCIM\100NIKON folder on the card. You won't be able to do this using Nikon Transfer or most other picture downloading utilities, so open up a couple of explorer windows for the drag&drop.
Sep 02, 2008 | Nikon Cameras
Sigma DP1 Digital Camera Logo
120 people viewed this question
Top Sigma Cameras Experts
Doberman
Devabhakthuni...
Devabhakthuni...
Are you a Sigma Camera Expert? Answer questions, earn points and help others
