Thin vertical red line on my LG 50PC56
I have just noticed a very thin vertical red line (much less than 1'' that some people are reporting) appearing on my LG 50PC56 plasma TV. It is only showing on some shades of blue at the moment. Is this a control board problem? The TV is about 30 months old so out of waranty.
  • 25 Answers
First you must clean connector contacts between plasma module and driver boards, if not solve the problem and continuing increment of wide red line, may be you must change plasma module to solve this problem,
Posted on May 28, 2010
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
50pc56 plasma hd lg tv got thin vertical line going down screen
When you see these thin lines they are caused by a few things. None of which are good.
On smaller tv's the lines can be cause by the contacts coming loose after being bumped. These can be either the contacts with the small ribbon cables or the contacts inside the actual lcd display. The connectors can be reinserted and sometimes that is all it takes. Generally the lcd panel can only be fixed by replacement.
The other thing that causes this are problems with ram/memory or timing issues. Either of those will require the board to be replaced. If the line is on all channels it is usually ram, if it showed only on the odd channel (when you first noticed it) then it is probably timing. Either of these issues require the mainboard to be replaced which is not cheap to do.
Unless you have warranty either through the store or OEM then this is not a cheap fix. The line may go away for periods but eventually it should get worse. The cost of repairs will be worth more than a new replacement TV. So the best advice I can give you is to get a repair estimate to make sure and know what a replacement tv is worth. If its not worth fixing just use the tv until the line gets too annoying or worse then replace it.
Dec 05, 2010 | Televison & Video
Vertical lines showing in picture, especially noticable on black
in these issue you can see vertical lines due to filter capacitors bad in the secondary power supply. 100micfarad/j35volts, 220microfarad/25volts.
Jun 09, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
Dec 17, 2008 | IBM NetVista PC Desktop
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Feb 11, 2008 | LG 50PX4DR 50 in. Plasma TV
Blue vertical thin line on Acer Travelmate 2410
It might be the case that the pixels of that line have become dead.This is a monitor malfunctioning and you shud report to your vendor.
Feb 04, 2008 | Computers & Internet
Televison & Video Logo
1,255 people viewed this question
Top Televison & Video Experts
