Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
I have a friend with a 15 year old GE Profile side by side refridge. The freezer is working the refridge side is not cooling down. She cannot get a tech out for 5 to 6 day's. I use to have a GE with the freezer on top and the heater that kept ice build up was out and I could take the back out of the freezer and use a hair dryer to thaw it out and keep it going till a tech got there. Does she have this option in a side by side?
    Top Expert:
  • GE Master
  • 79,865 Answers
There is really nothing to be done.
Posted on Jul 10, 2017
SOURCE: Ge profile Refridge...
Check the cooling coils, and very likely they are full of dust preventing cooling.
I have an attachment I put on my vacuum cleaner to clean out these coils at least once per year.
Posted on Dec 06, 2007
SOURCE: ge profile refrigerator
sounds like a defrost or sensor problem. or the main P.C.board. probably the board and sensors.
Posted on Jul 22, 2008
SOURCE: GE GSS 22KG SIDE BY SIDE REFRIGERATOR 6 YEARS OLD
The codensor fan is not running. I have the same problem. I had the fan replaced a year ago for the same problem, so I can't tbelieve it's the fan. I am guessing something on the circuit board is not letting the fan kick on. I don't have a definite answer yet, but the fan not running is the main issue you are having.
Posted on Sep 30, 2008
  • 833 Answers
SOURCE: GE TFX22CR Ice Piling up in Back of Freezer
You either have icing that you didn't clear or the unit is low on gas.  You might also try cleaning the condenser coils.  This is a big problem in cooling.
To check low gas:  After cleaning the condenser (!), clean around the piping to the compressor in the back of the unit.  Wait at least an hour with the unit shut off.  Restart.  The larger pipe should begin to frost up.  If after about 15 minutes the frosting gives way to: ice, wetness or drying out...the gas level is likely okay.  If it stays frosted, you'll need a gas recharge.
Posted on Nov 20, 2008
  • 54 Answers
SOURCE: My GE Profile PSS26MSTSS is not keeping food cold.
You need a new defrost heater
Posted on Jan 04, 2009
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
Woke up this morning and the refrigerator was running, but not cooling. I can hear the fan running, but the temp of the freezer continued going up to room temperature. It's only three years old, so I...
We have a GE side by side that was only 4 years old before it starting giving us problems. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board (appears to be a common issue with GE) was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Dec 03, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL FREEZING AND REFRIG NOT COOLING. DEFROST MANUALLY AND REFRIG COOLS FOR A COUPLE DAYS, THEN FREEZER COILS FREEZE AGAIN
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Nov 23, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
GE Profile TFX22PR side by side. Freezer works fine, but Refridge side is not holding cold temp and the door gasket is quite warm to the touch.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 02, 2010 | Refrigerators
Our side by side GE Refrigerator feezer is defrosting and the refridge side is barely cool. The fridge is only three years old. what should I do?
Look at the back wall inside the freezer from the middle down, if you see frost evenly on the back wall then the Defrost system has failed.
Posible fixes, Defrost limiter, Conttrol board bad, Heater Bad, Defrost timer bad.
if you did see the frost you could buy some time by defrosting the evaperator with a hair dryer. (( if you dont know what your doing the please call a appliance repair tech ))
Sep 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works Refridge does not get cold like it should
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<br /><br />Refrigerator not Cooling or Fridge not Cooling<br /><a href="http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not" target="_blank">http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not</a><br /><br />How to Defrost Refrigerator Defrost Timer Problem <br /><a href="http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer" target="_blank">http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer</a><br /><br /><br />Water Running in efrigerator from Freezer<br /><a href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target="_blank">http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</a><br /><br />heatman101</span><br />
Aug 26, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
I have a 10+ year old Kenmore side by side that quit cooling
the starter unit of the compressor can be bad EZ fix if it is that...its the element conected to the compressor :)
Dec 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerator not cooling
If it has a filter on the bottom, make sure that is clean.
Dec 21, 2017 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
