The temp light comes on,, found out it was one of the fans, put in new fan and fan is now working but i still get the temp light, it comes on for about 6 sec then turns off, When its on the green power light blinks, i checked all the other fans ok.. anyone have a wireing diagram, were are the temp sensors?
  • 10,594 Answers
Let me know model and brand of your tv to find out wiring diagram for you.
Usually temp sensor is mounted on or nearby lamp housing in dlp tv. Its 2 pin device fixed with screws over lamp housing to monitor temperature in tv.
Thanks.
Posted on May 27, 2010
  • Matthew Albert
    Matthew Albert May 27, 2010
    this is a epson ex50
  • Shahid Electronics
    Shahid Electronics May 27, 2010
    epson ex50
    Temp sensor in multimedia projectors usually mounted in mid of air flow in light engine. You need to check under that area where 3 LCDs are mounted. Temp sensor would be little tube type with two wires of connection.
    I'm afraid, no schematics/ service manual is available for that model so you need to work with your experience.
    Thanks.
My 2005 Jeep Liberty Renegade had a small crack on the top right side of the radiator. Replaced the radiator with new one. Put everything back together, put in new coolant and burbed it. Now when the...
the FSM book covers this.
how to test the fan.
you do this parked.
with a scan tool first. look for dtc errors hot.?
make sure the ECT reads correct using the SCAN tool.
180F+ is good.
the let car idle. it will overheat idling, they all do, but not in Alaska.
as the temp hits the PCM thresholds , the PCM commands on the fan and it runs, dropping temps back to 180F
(can i assume you put in a new thermosat with rad.
that be the perfect moment, they are short lived parts
and the numbers stamped on it it must be OEM spec, temp.
nothing else.
The fan relay closes at too hot temp (PCM decides)
the coil on relay goes to 12vdc (meter across pins)
if coil is 12v and 12v out of relay to fan is 0v.
then the relay is bad.
if the coil never goes hot, we have a serious problem.
the ECT must see the overheat, if there is an air pocket at ECT
it will not read temps, true, but why low, .
and fan will no come on.
that is how it works. most modern car.
Mar 11, 2015 | 2005 Jeep Liberty Renegade
Have replaced the main control board, and all the control panel lights now work, compressor comes on, fan inside comes on, but fan at bottom of refrig does not. Checked all connections and all is good....
Set you refrigerator controls at their middle settings. Put a thermometer in both sections. Check after several hrs. Freezer temp should read near 0 and fresh food temp between 38 and 42 degrees. Those are normal operating temps on most refrigerators.
Mar 06, 2015 | Refrigerators
Radiator fans do not work and engine overheats.
had the same problem in 1994 grand am, done all that and wiring harnness never found it , put jumper wire to ingition switch turn the key on fan came on.. its not right but it fixed it for ten years. before doing this check for power to relay look at plugs to relay and prongs for fuses. Some ans are controled by ingition switch, remove key from ring while running lift key see if it comes on
Sep 19, 2017 | Chrysler Grand Cars & Trucks
2000 acura tl coolant fan after fluid change
New thermostat, installed, saw, new coolant made a little mess filling reservoir, (normal) checked fan fuse for some reason, and condenser fan fuse (xxx ?:), and temp guage, is slightly lower on gauge (than normal?) (disconnected xxxx? quit? a bit? to get to thermosta?.t no dash warning lights have a feeling I popped a relay.
Answer:
ok, you did a coolant service with STAT,
and it failed.
tell us what works right and wrong, symptoms only.
over heating? parked, (fan never comes on)? as it hits 225F?
under heating? ( fan stuck on , up North can cause huge cold engine)
dash gauge stuck low. (thermostat wrong heat range 180f is best. see FSM for spec. on this temp. spec..
Dash guage varies.? oddly (air in system)?
Dash gauge too high.? (Stat put in upside-down or bleed hole (jiggle) not UP side. higher side of mount , trapping air.)
Does something wrong happen only driving?
leaks?
does cap on rad hold 12-14psi pressure, hot.?
if car has fan belts, are they tight? (for sure water pump does)
Nov 19, 2013 | 1994 Honda Civic
Radiator cooling fans won't work
Just a thought, some makes and models, if you unplug the coolant temp sensor, the fan/s may run? I believe it to be a default setting incase the pcm doesn't see the signal from coolant temp sensor. Any applicable trouble codes? Do you want a wiring diagram for radiator fan?
Jan 27, 2018 | 2007 Pontiac Torrent AWD
1999 Honda Shadow Aero, temp light on fan not coming on
yap it has a termo sensor, if it fails, your fan wont turn on, and also check the auxilliary fan relay.
May 26, 2012 | 1999 Honda VT 1100 C3 Shadow Aero
I have 97 Polaris Express 400 I haven't ridden in a while. Put new battery in it, new fuel, cranks, runs great but overheats. I checked the radiator reservoir and it is full. Any suggestions? How can I...
U should have two sensors for the cooling system one is nerr the thermostat housing for temp light / gauge ,one on the cooler at the bottem left side should have two wires on it need to pull them off connect the two togather. That should make the fan come on, if not, look for a popped fuse should invest in a handheld inferred thermometer ,there really cheap .get them on eBay for between 11 to 20 bucks brand new use it to test temp on coolant hoses to see temp on top and bottom .if fan does come replace cooling fan temp sensor.
Mar 03, 2018 | Polaris ATV
Over heating. four machanics checked ( dealer said nothing wrong, not over heating for them ) they changed temp. sensors they say. They check hoses and said all good. the radiator fine too. radiator does...
You have two fans, one should cycle if the engine gets up to temp. say 190degs. The other should come on if you turn on the A/C. So start the engine check the fans, then turn on the A/C recheck the fans. One should be running with the A/C on. If not, this is the cause of your overheating problem. Check all your fuses, go to a local parts store and have a clerk check the fan relays.
Jun 06, 2010 | 1998 Dodge Caravan
Fan motor not working
It sounds like the water pump is not moving any water or there is not enough water in the system. This would leave the radiator cold - i.e. no fan, and the engine hot, i.e. temp light.
Oct 29, 2009 | 1989 Oldsmobile Cutlass Ciera
Temp lite blinks
Your ballace is most likely out. If not that your light engine is going out. You may be able to get a rebuilt one from www.vancebaldwin.com it will come with a new fan, and ballace.
Jan 19, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
