Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Everything has stopped working. The thermal
Everything has stopped working. The thermal cutoff mounted on the side of the circuit board is open. I have replaced this cutoff three times in the last 6 months. What is the purpose of the cutoff and what could be causing the problem? could line surges or interruption of power be the problem?
  • KitchenAid Master
  • 19,396 Answers
Hi. This is not a thermal cutoff: FUSE-KIT (Fuse Kit and Wire Harness). This is a fuse that blows when there is a contact. Frequent power surges can also cause the fuse blowing. Otherwise the fuse may blow because of a contact that ocurrs occasionally because of vibration. When there is a thermal cutoff, the thermal cutoff will blow because of overheating. In that case ither the thermostate is defective and it is shorted or cutting too late, or the heating element is plugged. In your case the problem is not overheating. Try to understand if the fuse blows because of a power surge, or when the machine is working. As said, fuse can blow because of power surge, because of contact, defective control board or a short in wires almost anywhere in the appliance. Try using a surge protector and see if this can fix the problem. Regards. Ginko.
Posted on May 27, 2010
I have a kitchenaid YKESS907SS00 and the front display and all functions of the oven do not work. The range works fine. I need help to troubleshoot what is wrong with this darn thing.
I brought the schematic remove the front panel be sure to unplug if you know to use a meter you need to check continuity thru the thermal cutoff and thermal switch if one is found to be open then there is no power going to the control board
Feb 14, 2015 | KitchenAid Kitchen Ranges
Wolf microwave timer counts down, lights on but not cooking or making noise when started
You need a magnetron. While the cabinet is open look for melted wires, check the circuit board for burned components. Check thermal cutoffs for continuity etc
Nov 26, 2013 | Microwave Ovens
Has power but won't heat
replace your magnetron While the cabinet is open check the thermal cutoffs and look for melted wires Tap the relay in case it sticks Check the circuit board for burnt traces or components etc
Nov 26, 2013 | Frigidaire Built-In Microwave
Umc5200bab w s
open it up. Look for burned wires. look at the main circuit board for overheating or burned components. Likely you didn't find anything. Check the thermal cutoffs for continuity. Likely the only part you need is the magnetron.
Nov 25, 2013 | Microwave Ovens
My Diplomat ADP3300 fan assisted oven has been turning off when trying to heat up, but has now completely turned off. I am an electrician so have checked the obvious stuff but not sure what I'm looking...
I'm an electrical engineering technician college dropout. :) But i have had 30 years experience troubleshooting and working on electronics and appliance repair on occasion. I would look for the circuit board. It could have burned circuit traces or a failed voltage rectifier. Sometimes the whole board just needs replacing. Most boards that have relays have relays arcing and sticking inside at times too. If it isn't that then there is not much more than a thermal cutoff that could be the problem. They can be tested for open circuit easily. Also if the fan ever stops turning the thermal cutoff could be a safety feature to prevent overheating.
Nov 08, 2013 | Ovens
MICROWAVE IS NOT HEATING--EVERYTHING IS WORKS FINE
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may have to replace the capacitor as well. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Feb 02, 2013 | GE XL1800 1100 Watts Microwave Oven
MODEL # GSH22JFTAWW won't go into defrost had board changed out and the element and the temp sensor and temp limit sensor how do you put into defrost mode maunally and what is wrong with it have to...
Which temp sensor did you replace? The one that clips to the top of the cooling coils is the defrost sensing thermistor. The other "temp limit sensor" is thermal cutoff switch that opens the defrost circuit should it get to warm. Be sure you got the right part for this! There are a couple of different temperature rated cutoff thermostats out there and this model uses a pretty high temp rating.
As to your question of manually putting it into defrost, you would need to unplug the refrigerator and disconnect the power ******** of the control board (the only jack that mounts parallel to the board and should be a green colored three wire connector. The terminals on the board should be labeled "comp", "line or L" and "def". You will need to put a jumper wire between the line and def wires on the wire connector (not on the board). Plug the fridge back in and your defrost circuit should be energized.
Good luck with this!
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool oven stopped working after self cleaning
If the display still works but neither the Bake or the Broil elements wont heat up, it's likely that the Thermal Cutoff has opened and has not reset itself. This is a common problem after self Cleaning.
The fix is to replace the Thermal cutoff which requres you to pull the oven and remove the back panel to get at the thermal cutoff.
What happens is that in Self Clean, both Broil and bake elements are used and the oven gets so hot that the middle skin (between the oven liner and the back panel, where the thermal cutoff is mounted gets so hot the thermal cutoff operates. It should reset itself but sometimes doesn't and then you have to replace it.
Nov 17, 2009 | Whirlpool RBS305PD Electric Single Oven
Iron won't heat up
well its had it chuck it out
Jul 18, 2008 | Audio Players & Recorders
Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Feb 20, 2008 | Dryers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
139 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
