Question about Xerox Phaser 6250 Laser Printer
How do you use photo paper in a xerox phaser 6250?
  • 241 Answers
If you want to use photo paper for your Xerox phaser make sure the photo paper is meant to be used in your printer. The best paper would be the Xerox brand photo paper which is made to be used in the Xerox phaser printers. You use them like normal paper and print your document or image onto the paper. If you cannot find the paper that works with this xerox printer go to the Xerox website and under supplies, then entering your printer model it will give a list to the paper recommended for this model.
Posted on May 28, 2010
4 Suggested Answers
SOURCE: My Xerox Phaser 6250 won't duplex all of a sudden
I don't have an answer, but I can add some detail since I have the same problem (6250 that suddenly won't duplex).
I have a wired network with multiple Vista machines connected and have been duplexing just fine for YEARS with the same PCs and same drivers. One day my wife complained she couldn't duplex and I messed around, updated drivers, rebooted everything, etc. etc. and finally gave up and sent the print job from my laptop where it duplexed just fine.
About a week or so later I noticed that my laptop would no longer duplex either! Once again I updated the drivers, rebooted, tried different settings, etc. etc. but no luck.
I'm pretty convinced that a Windows patch has caused this issue (which is why there is a timing difference between my machines). I've rolled back my system to remove several patches and things seem to work fine again, however I'm not exactly sure which patch causes the problem AND within a few days Microsoft reinstalls the patch automatically.
Unfortunately I'm not confident that Xerox will put much effort into fixing this driver problem since this is not only an "old" printer, but I don't think many people do much duplexing (so there won't be many people yelling for help).
I'll let you know if I find a better work-around or fix.
Posted on Jan 06, 2010
  • 2072 Answers
SOURCE: im getting an error not a genuine xerox product on
You may have gotten a cartridge meant for another region. Like Canada or Europe, I have seen it happen. Call them and ask for a replacement.
Posted on Mar 03, 2010
SOURCE: Xerox Phaser 6250 won't print colour in Windows 7
Hello!
I had same problem and it was driving me crazy. Try this one:
Control panel -> Devices and printers -> xerox printer with mouse right click
Printer properties -> Options
From list you'll select configuration and it gives you drop down menu and from menu you need to select your printer.
I didn't try this one yet because more solid ink is still on the way but this gave me all printing options back. Before basic printing mode was selected.
Funny stuff, uh?
Posted on Mar 18, 2010
Testimonial: "see my added comments - thanks again"
How do I find the page count for the printer
Phaser 6250 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-6250/support/enus.html
XeroxProduct support for Phaser 6250. ... with our support knowledge base directly, and troubleshoot itself. Automated Remote Diagnostic Tool - PhaserSMART™ ...
Oct 02, 2015 | Xerox Phaser 6250DP Laser Printer
Phaser 6250 DP keeps on jamming at Fuser.
Paper type set correctly? Does the paper enter the fuser? If not, the fuser drive has failed, replacing the fuser may correct it.
Nov 19, 2010 | Xerox Phaser 6250DP Laser Printer
Xerox 6250 will not warm up. it says
Yes it can be the used fuser. Kind of odd for it to be anything else but the fuser.
Jan 25, 2010 | Xerox Phaser 6250 Laser Printer
Phaser 6250-Tray 2 continuously ask for A5 Paper
Adjust the side guides in the paper cassette tight against the paper stack.
Jan 25, 2009 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250N Jam at Registration Roller
I use to have the same problem, but downloaded a fuser patch at the Xerox site:
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company=%7B5AC8CA72-62D5-4658-8D6F-D2F393C98A63%7D,ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1001052703
if that link doesn't work, go to the Xerox site and look in the area:
Home > Support & Drivers > Phaser 6250 > Knowledge Base
ID: R1001052703Phaser 6250 Support Knowledge Base Jam at Registration Roller (code Jam RR)
Follow the instructions and hopefully your printer problem will be resolved.
Apr 18, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250
How Brave is Jan?
Doubt it be the fuser(100 000life), "just magenta dots".... fuser would be "all smudged" or "black marks" , "the print rubs off" , "paper is creasing or jamming"
Can prove it by stopping a print (open door) when paper is1/2 way threw machine, you need to stop it before it goes threw the hot bit, so you can tell if the hot bit (fuser) puts the marks on the paper.
Transfer roller one would expect to effect whole print Smudged/Faint,uneven density
It will be the imaging unit ( 30 000 pagelife Ouch$ ) or possible leaking toner (if aftermarket)
Remove imaging unit and inspect film you should find image of lines, dots are usually chips or sticky stuff on drum surface, carefull no oily human fingers on surface please.
When stopping machine mid print and perfecting your timing, pull out the imaging unit and look at replica of your print notice if marked and where.
Hope this helps
Nov 19, 2007 | Xerox Phaser 6250 Laser Printer
Xerox Phaser  6250 Laser Printer Logo
171 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
