Question about Hitachi 50V500 50 in. HD-Ready LCD Television
I have a hitachi 50v500 ultravision lcd tv and the lamp light is on. Do I need a new lamp bulb, and if so, which one?
  • 94 Answers
Part number:
UX21511-C
Posted on May 28, 2010
Hi, i have a ultravision digital hitachi 50v500 , theirs a light bulb in the tv that needs to be replaced. how much would that cost to fix it?
Replacement lamps with housing will cost between $175-200 at a retail store, this does not include installation. You can buy a lamp without the housing for near $75-100 but this requires you to remove the old lamp from the housing and installing the new lamp into the old housing, which can be tedious and potentially damaging if you do it incorrectly. BUY THE LAMP WITH THE HOUSING it will save you time and frustration.
Mar 03, 2011 | Televison & Video
My tv has a yellow, green or blue tint to it. We think it needs a new picture tube. Do you think that is the problem and if so is it easy to do myself
You have Light Engine Failure. Only fix is replace the Engine. Here is a Page that shows Hitachi LCD Projection TV Optical Engine Faults.
Check for these faults before spending money on a failed bulb. Here is page with all Hitachi TV Lamps and Bulbs.
Feb 11, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
Put new bulb in hitachi ultravision dlp tv and lamp light flashes and tv will not turn on. Have reinstalled old build and works fine. Is there any type of reset that needs to be set. New bulb no tv, old...
hey there it sounds like the problem is coming from your ballast board, the ballast board is the power source to the lamp. with time this part starts to wear out and get weak your old lamp is already burning out there for it does not need that much voltage to turn on but the new lamp has not been worn out or used there for it needs the ballast to be working at 100%
hope this solution helps
Sep 03, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
I have hitachi 50v500 my screen went black and the lamp light comes on by the power button
Lamp light ON means TV needs new lamp as existing lamp is either broken or dead.
Replace lamp in TV, replacement procedure would be written in user manual.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
We have a 50V500 Hitachi Ultravision TV, temp and lamp light started flashing and then the lamp light stays on steady, now TV will not come on.
Howdy,
You need to replace the lamp; UX21511 about $100.00 for a replacement. It is very easy to replace.
Good Luck, big IRISH.
Dec 28, 2009 | Televison & Video
Hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Feb 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500, no picture ,sounds for about 15 sec.then goes off
I would try to re-seat the lamp. Pull the lamp out, check it to see if it may have gone bad again, then put it back in to make sure the contacts are connected. Before applying power, unplug the TV for 5 minute, and then plug in/turn it on.
Most lamps, if bad from the factory, will go out within 3 months of use. It does happen, and happens more often than you would think.
Try this, and see what happens. Good luck.
Jan 05, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
417 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
