Question about Lexmark X1270 All-In-One InkJet Printer
Cables? i've just moved and not sure if i have all of cables for the printer. Is their any way that you could show me what the cables llok like , so that i can see if I do have all of them?
  • Anonymous Apr 13, 2008
    purchased for daughter for christmas, she just finally went to install but says she is missing (cable?) part that attaches computer to printer,
    Scholar:
  • 50 Answers
You need a USB cable. The printer does not come with it in the Box. Check out this walmart link
or see this link for pictures of USB cables
Posted on Apr 10, 2008
Printer wont print. error message says" print unable 51 see troubleshooting & routine maintenance chapter in users guide" I have no users guide!!
Maybe is you should provide the brand and model or you unspecified printer, could findyou the manual, if available.
You can llok for it too, search google with terma
manual, brand ans model
May 17, 2015 | Office Equipment & Supplies
I`ve a problem in system appear this word''error e225''why?&what do i shall?
disconcent form data cable tahn restart printer unistaal your printer software than connect ypur printer than instaal printer software i am 101% sure your problem will be solved ok
Nov 13, 2014 | Canon LaserBase MF3220 All-In-One Printer
Label writer 450 is only printing half a label and then the blue light flashes like it is out of paper. New roll, worked fine before it ran out
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
Disconnect the USB cable and the power cable to reset the printer. Check if the roll is loaded properly - the holes between the labels have to be on the left. Connect the power cable. If the blue light is solid, connect the USB cable and try to print.
Check the DYMO Label version (Help > About). If it is below 8.5.0, you have to update it.
^CM
Feb 08, 2013 | Dymo ® LabelWriter® 450 Series PC...
06 PONTIAC TORRENT LOCKS AND UNLOCKS AND FLIPS FROM PARK TO REVERSE WHEN PUT INTO PARK
the two problems are not associated ,the lock problem is caused by a problem in the door itself and sometimes removing the door panel and giving a good oil with a proper oil can with engine oil in it will lubricate a sticky connection but the drive cable problem iam not sure of and without a good look i defy anyone to know whats wrong but i do suspect the lock mechanism where you have to put your foot on the brake to move it and this is defective in some way best advise i can offer is to ask a local mechanic to have a llok for you
Sep 24, 2012 | 2006 Pontiac Torrent
Deskjet F2180 not printing with Mac OS X 10.4.11
When you installed the new software did you delete your old print setup in the printer preferences as it may be conflicting with the new driver. I would delete all appropriate hp F2180 printers from the printer preferences and then install the print software again. When you do that does your printer show up? if it does not show up there could be a problem with the usb cable or the usb port on the back of your mac, swop it into another usb port, if it still does not show up, use a different usb cable. Hope this helps.
Jan 09, 2012 | Office Equipment & Supplies
After loading the system shows error 'cannot recognize usb port'
According to your problem, first make sure that the USB port of your system is OK and working fine. Connect another plug and play USB device to this port or move to another USB port. Check that you have connected the USB cable properly. You can reinstall the driver and reboot the printer and the system both by follow the instruction of printer installation manual. Check the USB cable of the printer or replace the cable. It will help you.
Jun 10, 2011 | Canon LASER SHOT LBP-2900 Printer
Hi I've Vaio VPCSC1AFM with Win 7, boot is impossible -"Operating System Not Found", HDD is also not visible in BIOS. I can hear that HDD is working.
* Look in your BIOS, I've it can detect the HDD.
( Press the F1 or F10 key after restarting the computer) * Make sure all the cables are connectedproperly.
* It might be a jumper setting.
I've you have 2 HDD's on 1 cable, you need to have 1 Master & 1 Slave,or else your HDD(s) wont show up & other problems.
Jumper settings below (Yourjumper settings might be different !)
I've this all didnt work, either your HDD or your MOBO is broken.
Jun 03, 2011 | Computers & Internet
I`ve just purchaced a kodak esp 5250 printer.and im unable to connect to my bt home hub wireless . I`ve followed the instructions that came with the printer Can you help.Thanks
You can try to check if you have done the steps here. If everything fails, you might consider getting a USB cable to connect the printer directly to the computer first and use the Kodak Printer Setup Utility to connect. Make sure to install the printer's driver and software using the disc beforehand.
Apr 14, 2011 | Office Equipment & Supplies
Hi there, i would like some help i got an Samsung CLS-3175FN Color Laser and all of the sudden started to show "SYSTEM ERROR CYCLE POWER", i´ve looked around in this site and there are some comments...
> CYCLE POWER
Turn the printer off.
Disconnect the power-cable from the wall-outlet.
Reconnect the power-cable.
Turn the printer on.
This is the full "cycle" from ON to OFF to ON.
Oct 11, 2010 | Samsung Laser Multifunction Printer Toner...
Will not print
Make sure you select the printer has the default printer under the Printers and Faxes option on control panel.
Simply right click your printer and select the option "Set as the default printer"
To make sure it is solved, go to the printer properties under the right-click menu and hit "Print test page"
Good luck
Jun 21, 2009 | Canon BJC 80 InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
