Samsung SH203N Our Samsung DVD drive SH203N (20X) doesn't write at the speed we set it to, I have some 4X discs that DVD decrypter says the supported write speed is 2.4X, I set it at 2.4X, but it burned at 8X. A 16X disc burns at 8X. It seems everything burns at 8X, no matter what I set it at. With Gear Video, the settings are grayed out, I can't set it. It said it was burning at 2X, but it must have burned faster than that, because it was done fast. Last night I burned 2 discs that had this error when verifying: Read operation was not successful. Internal error on the recorder Driver error code: 02043E02h The disc in the drive is not successfully recorded.
  • tehtran Mar 31, 2009
    I have similar problem. I have the Samsung SH-203 F/W:SB01. When I used Nero v.8 to burn DVD-ROM (.jpg data), It gives me error "Burn Failed at 2.4x (3,324,KB/s)". Details of the error was " DMA Driver error, CRC error... Drive SH-S203..."
    If you know how to fix this issue, please post your suggestion.
    Thanks!
Well you could try to set it to the right speed and then maybe you never no it could actually work and you would get more custmers.
Posted on May 11, 2008
6ya staff
SOURCE:
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
I have a samsung external dvd writer, now i've got a problem because it can not be recognized anymore when i insert it into my pc. what is the main cause of this problem and how to fix it? can you give...
Try to plug it to other USB port of your PC I recommend you plug it at the USB port at the back of your CPU..If this doesn't solve the problem try to clean your DVD drive lenses with a DVD cleaning disc..Still if this doesn't solve the problem perhaps you'll need to contact a technician or for worse buy a new external DVD..Hope it will help you..
Jul 11, 2011 | Samsung 20x External Double-Layer DVD...
Can you tell me some specific Brands of DVD-R or DVD-RW blank disks? I have tried several and cannot find many that will work with my Sylvania SRDV495.
There are no specific brands, however Verbatim are widely considered the best. Your, problem, however, is unlikely the brand of the media and more likely the recording speed of the media. Most blank DVD's on the market are 16x or faster and your machine (c. 2005) doesn't support anything faster than 4x. When I was reading the manual it referred to the "state of the art" 8x discs that the machine didn't have the ability to support. The discs you need are available and often are labeled as 2x - 4x meaning that they will support any drives that burn at a 2x - 4x spin rate. Also, be sure that you are not purchasing DVD+R and DVD+RW as they are not compatible with your unit.
Manual
Jun 22, 2011 | Sylvania SRDV495
I have a never-been used PD-800 DVD player, when I put DVD in - it says - "wrong disc". What could be my problem? Thx. Ray
there are mauy different dvd applications did you read what type if disc to use a lot of older units use dvd ram disks and can't use regular also try a dvd - disk and a dvd + disk the speed of the disc also plays a roll in weather it will work or not
4x 8x 16x 20x check the manufacture
Mar 01, 2010 | Televison & Video
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
How do i increase my dvd rw drive speed
Not all "blank" disks are alike.
Some support only '4X' or '8X' writing-speed.
So, buy blank disks that support '48X' writing-speed.
Not all DVD-writers are alike.
Upgrade to a DVD-writer that supports '16X' or '32X' writing-speed.
Not all USB ports are alike.
USB 1.1 ports support 11Mbits/second,
while USB 2.0 ports are about 10 times as fast.
Check that your USB device is connected to a USB 2.0 port, not a USB 1.1 port.
Dec 27, 2009 | Samsung External Slim DVD-W USB Compatible...
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Won't Read blank disc!!
    Ok, I talked to Samsung support again today, and they confirm that the firmware update should correct the problem of incompatibility with 1-16x discs. They are going to mail a CD with the firmware update to me, at no charge. They were not, however, able to tell me if the file I had originally downloaded from their website was the same as what will be coming on the CD. Sheesh!!
    If I can determine that they are the same file, I will post such info. here later. Otherwise, I would advise contacting Samsung support and requesting a disc.
    The phone no. is:
    1-800-SAMSUNG (1-800-726-7864)
    Mon - Sun : 9am - 9pm (EST)
    Apr 12, 2007 | Samsung DVDR120 DVD Recorder
    Open Questions:
    Computers & Internet Logo
    428 people viewed this question
    Ekse
    Marvin
    Marvin
