Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven does not work,
Loud noise, fuse blew, oven does not work, but top of stove does.
    President:
  • 1,430 Answers
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at http://appliancehelponline.com/ovenelementvideo.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
If the element checks good it probally blew the relay on the main control board you will know this if you have no power to the element.
Posted on May 27, 2010
If i blew a relay then i need a repairman?
Posted on Aug 26, 2010
Are there fuses in the whirlpool flat top accubake stove that control the oven?
Yes there is a thermal fuse for the oven that if it blew all power to the oven would be cutoff,the fuse is not resettable and if it blew would need to be replaced
Aug 05, 2011 | Ovens
I have a 2 yo fridgedare stove that the oven went out..the stove top is working but now oven isn't? The other day while i was cooking a loud noise like a "boom" happened and now oven not working?...
The noise you heard was probably the oven element short circuiting to earth. If the cooktop and grill are working then the fuses, internal/main must not have blown. If this is the case the oven indicator light should come on when you turn the oven on. If it does the oven element is definitely faulty and needs replacing.
Mar 05, 2011 | Frigidaire Ovens
During cleaning process, blew house breaker. Reset
Seems like you found out the hard way what I wrote about in this tip...
Yuor wiring has been incinerated with the stuff in your oven...
Yes, it can be fixed, depending on what and how much has burnt...
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 23, 2010 | Kenmore Ovens
1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Jul 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When I had two of the stove top burners on and I heard a loud pop. Now nothing works. The oven or stove. What should I do?
sounds like a wire may have shorted. This will trip the breaker or fuse, which ever you have. It will possibly burn the wire in 2. Need to check for separated/ burnt wire.
Jan 19, 2010 | Ovens
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
How do i install an oven thermostat?
You crossed wires or missed one and blew something out.
Feb 16, 2009 | GE JKP15 Electric Single Oven
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
681 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
