Question about Proform CrossTrainer Treadmill
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
When the treadmill runs without me on it the speed stays true to the speedometer, but when I walk on it it will suddenly surge and runns very fast or suddenly decreases in speed.
    President:
  • Proform Master
  • 832 Answers
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
Posted on May 31, 2010
Proform 400 GI - Treadmill
go under the HOOD cover the instruction for RUN the software calibration for easy diagnostic , and fix it.
God bless you
Jul 07, 2013 | Proform 400 CT Treadmill - Treadmills
My proform 350s crosstrainer turns on but belt has stopped. trouble checked using the voltage diagram....all lights on board show as they are supposed to. help, please.
Dear Sir:
The problem is a worn treadmill belt and deck.
Most of the time not lubricating between the treadmill belt DECK vs deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
Try to RUN the software calibration for easy diagnose +trouble
See my personal TIPS for HELP
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 13, 2012 | Exercise & Fitness
How do you set the distance to miles
Dear Sir:
Hello, I hope everything is fine.
I will help you inmediately.
Things You'll Need
  • Pencil
1.
    • 1
Switchthe power off without unplugging the machine. Do not take the safety key out ofits place.
    • 2
Inspectthe bottom of your console. The calibration switch is in a small hole. Insertthe eraser end of a pencil into the hole and softly push the button. You willsee CL11 on your console after you push this button.
    • 3
Usethe Speed + or - key to select MPH or KPH. Push the Power key to save yourselection.
Thank you in advance, sincerely. God bless you
If you need further assistance, please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Proform CrossTrainer Treadmill
How do you adjust the belt on the ProFrom 350s. It'swanting gradualy drift over to one side (Left). Thank you
There are Allen bolts on both sides of the base, on the end away from the console. Turn one bolt one way the other the other way to move the belt from side to side.
Aug 10, 2011 | Proform CrossTrainer Treadmill
Converting kph to mph
press and hold the stop button while placing the key on, then release and hit speed + or - I don't remember which right now. One turns the store demo on/off and the other is for mph/kph
Jul 14, 2010 | Proform CrossTrainer Treadmill
Belt jerks with each step. At first it hesitated with random steps but has become more pronounced. I walk at 3.5-4MPH but belt does it at any speed. It is not plugged into a surge protector.
I have the same problem with this type of treadmill but only when running on it. I usually increase the incline to prevent it. I believe the tension on the belt has become loose. I have been looking for a guide on how to tighten it but havent come across one yet. If i find one ill post back with the link.
Jun 21, 2010 | Proform CrossTrainer Treadmill
My proform treadmill goes 10 mph no matter what speed it's set at
That treadmill has to be calibrated upon replacement of controller. Contact the place were you bougth controller and request calibration procedure. Hope this helps.
Apr 28, 2010 | Proform CrossTrainer Treadmill
Proform CrossTrainer Treadmill Logo
879 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
