Question about Sharp AR-M355N Copier
I have a AR M355N and it gives me "finisher out of service." Do I need all the trays installed to clear this?
  • Sharp Expert
  • 1,326 Answers
Maybe? Most likely the problem could be with the stapler unit not finding HP. Did you have a error code before the finsher could not be used?
Posted on May 28, 2010
Call for service. Code: L4-02
You need to make sure the machine is in Copy Mode then hit
Pound, Star, C, Star
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jun 25, 2014 | Sharp AR-M355N Copier
Sharp copier USB connection not recognized
WHAT OS U USE?
TRY THIS LINKS......
http://www.solvusoft.com/en/update/drivers/copier/sharp/ar-m355n/sub-models/
http://iprinterdrivers.info/download-driver-for-sharp-ar-m355n-printer.html
http://www.sharp-world.com/products/copier/downloads/index.html
AND ALWAYS U CAN GO FROM -CONTROL PANEL- TO -DEVISE MANAGER- AND FROM THERE U SEE THE PRINTER DOUBLE CLIK ON IT AND U SEE INFO OF DEVISE(PRINTER) LIKE DEV ID (DEVISE ID) COPY THE ID AND GO THERE
https://devid.info/ AND JUST PASTE AND FOUND THE DRIVERS
Oct 13, 2017 | Sharp Ar-m355n Copier Printer Scanner Fax...
Sharp m355n error code L3-00
L3-00 means that the scanner (the light under the glass) isnt moving correctly. You can reset it by pressing clear, interupt,0, interupt, 14,1, start button. Good luck
Jan 23, 2014 | Sharp AR-M355N Grayscale Copier
I'm trying to use my Sharp AR-M355N as a scanner for the first time. I've already made sure it's properly hooked up to the network and have successfully printed to it. I scanned a test page, put in the...
When scanning to e-mail you would need to enter the details of a smtp server e.g. Gmail, as well as your DNS settings into the photocopier via the web browser. To access the browser, enter the I.P. address of the copier into the web address & this will give you the front page of the copier. To access the network settings you'll need the user name : admin & the password Sharp. Depending on the firmware version the machine must have SSL installed, if it hasn't then unfortunately you will not be able to scan to e-mail. The alternative is to scan to SMB (folder), again this is set up via the web browser.
Hope this helps.
Dave.
Aug 26, 2017 | Sharp AR-M355N Copier
Finisher is not working trying to disconnect from copier cannot find cord
There is not a cable to unplug. The finisher is part of the copier. It is not a easy task to remove it.... Why don't you just turn that off as a option in the user mode.....
May 12, 2010 | Sharp AR-M355N Copier
Intermittent doc feed on ar-m355n, sometime overlaps pages? service note or bulliten on a modification or?
If you have not replaced the Adf paper pick up & paper feed roller & the seperation sheet, I would do that, also have you ruffed up the shaft with the one way ball bearing on it? Try that and have you cleaned the paper feed clutch's.. Good Luck...
May 27, 2009 | Sharp AR-M355N Copier
How to fax?
You access the fax functions (if optional kit is installed) by way of the Image Send button on your panel. Press Image Send, then press the FAX key on the screen. dial as you would any fax when the number is dialed and the document is in the feeder, press the start (copy) button and you are faxing...
Les Olson Company, Sharps #1 ind. Dealer in the USA. Selling Sharp in Utah and Las Vegas with 7 locations to serve you.
Feb 03, 2009 | Sharp AR-M355N Copier
Sharp AR-M280N
Does not need a fuser. Hit P * C * then hit 14 then Start ( Like making a copy) hit 1 and start then CA button. Machine will reboot. If code comes back, check the stapler to make sure it is in the proper home postion.
Don't forget to rate your answers please!
Jan 11, 2008 | Sharp AR-M280N Copier
Sharp AR-M355N Copier Logo
298 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
