Question about Samsung ML 2525 BW laser Printer
Red light flashing inside of a triangle. Doesn't
Red light flashing inside of a triangle. Doesn't print
  • 468 Answers
Replace toner cartridge
Posted on May 27, 2010
Something is wrong with the printer inside it open it up and see if any paper is stuck inside it.. if something is not wrong then u r wrong thinking is wrong ..!!
Posted on Oct 19, 2011
What does a red circle with a red triangle an ! Inside triangle mean on a 2004 audi
Electronic Stabilization Program (ESP)
The light will flash if you are driving and the traction control system is activated (it detects wheel slip on ice, water, etc.). This just tells you it is actively working. You should adjust your driving to the current road conditions to prevent loss of control.
If it stays on continuously, the traction control system (ESP) is off, or there is a problem with the ESP system. Usually, the ABS light will also illuminate if the ESP light is on due to a fault.
Apr 06, 2016 | Audi Cars & Trucks
Wil not print, Red light with exclaimation point in triangle flashes
You might have a paper jam ... For a most accurate diagnosis you might use control panel app from samsung website
Mar 11, 2014 | Samsung SCX-4500W WiFi Multifunctional +...
I bought the Polaroid Pogo mobile printer.when I first used it, it worked well.today I tried to use it and it is just not working. My phone seems the picture but the printer gets a red flashing light how...
That depends on which red light is flashing. If the battery light is flashing, that means the battery is exhausted. Fix it by charging the battery.
If the status light is flashing red, that means the paper is jammed. Fix this by opening the paper door and pulling out the media. Full instructions are on page 3 of the manual.
The battery light is the one marked with a battery. The status light is the one marked with an exclamation point inside a triangle.
Feb 12, 2012 | Cameras
My printer will not print the orange light keeps flashing what can i do i got a refill cartridge
Hello.
Hold down the Stop/Reset button for approx 10 to 15 seconds (it has a red triangle stamped on it).
This dis-ables the ink level monitoring and allows you to print.
Regards GM
Jul 15, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Flashing red light under ! triangle.
If the red light is on and you just put a new cartridge in it some times shorts the fuse so try:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends, the electrical contacts are notin the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
Apr 25, 2011 | Samsung ML-2571N Laser Printer
Light with the triangle flashing - printer stopped
That means ATTENTION, you are either out of toner or have a paper jam.
Feb 18, 2010 | HP LaserJet P2015 Printer
Paper light flashes red...
I found just doing this one simple thing sorted the problem.
First take off the front cover. Pull the tabs on the side. Pull out the big toner and cartridge. Do you see the blue tab on the top shaped like an arrow/triangle? Slide the tab from right to left - reinsert toner close door.
Hope it works for you
JPW
Aug 30, 2008 | Brother HL-2030 Laser Printer
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Carriage hits the right inside of printer - will not print
if the lights are flashing along together there is a cariage stall. The ink cartridge craddle is hitting something. Find out what and remove it if doesn't belong there. First of all remove and reinsert both cartridges. One of them may be inserted wrong.
Mar 19, 2008 | Office Equipment & Supplies
Samsung ML 2525   BW  laser Printer Logo
1,567 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
