Question about NetGear RangeMax WPN824 Router
DG834PN rangemax When the power adapter is connected all 4 LAN lights come on, then the router powers off. Can anyone help me!!!
  • 48 Answers
Try a different power adapter. If same problem persists, call Netgear support for replacement 1-888-638-4327.
Posted on May 09, 2008
I need help hooking up the router , i need the diagram showing how to hook it up to modem and vontage modem please help me
This router has ports in the back which are marked and also of different color.
Here is how to connect everything.
Make sure everything is Powered Off.
The cable from the wall goes into the modem, this is usually either a Coaxal or a phone (DSL) cable, the color of the jack on the modem should be green
Then there will either be 1 or 4 Yellow color jacks on the back of the modem, use one of htese to connect to the WAN link port on the router. there may be 1 or 4 LAN ports on the router, plug the Vonage Device into one of these LAN ports, power all the devices and start with the one closest to the wall.
So>
Modem first
Router next
Vonage device last
Jul 17, 2011 | NetGear N150 / RANGEMAX 150 Router
No LAN output from router
This router has 4 LAN ports and 1 WAN port. If you mean to say like if you are running out of LAN ports or if you require more LAN ports to connect more number of computers. Then you can buy a network switch which will help you connect more computers. All you have to do is run a ethernet cable from router's LAN to switch LAN
Aug 09, 2010 | NetGear RangeMax WPN824 Router
Setting up a wireless lan
The DG834PN is an easy to set-up, single box solution, it plugs straight into your ADSL line – there is no need for a separate modem. Once the DG834PN modem router is connected, configuration is also easy, via NETGEAR’s Smart Wizard™. The Smart Wizard™ automatically detects your ISP’s network settings, and then walks you through each step of the installation process. Or then Call ur ISP.
Thank You,
Your Tech Support,
Fixya.com
Manish Shirsikar
May 18, 2009 | Gigabyte GA-K8NS Motherboard
Can not install my router
First of all power off the net gear wireless adapter and than try to install the rangemax. if it dosen't work than please check the dhcp range in both the wireless router are the of the same range. than kindly the change the range of dhcp of this new rangemax wireless adapter. you can change this dhcp range my connecting the router to your computer and login by default ip . e.g http://192.168.1.1 and login with userid "admin" and password "admin" than go to lan management option and try the same.
Dec 03, 2008 | NetGear RANGEMAX WNR834M Router...
Need to connect router to deck top.comp.
This might work for you. Now to go in and configure the router thats something totally different.
To physically install the router
Step 1: Connect the power adapter Connect the power adapter to the router and plug it into an electrical outlet not controlled by a wall switch.
Step 2: Connect the router to the computer Disconnect the ethernet cable that is connecting the broadband modem to the network adapter in the computer. Connect the ethernet adapter in the computer to one of the LAN ports on the router.
Step 3: Connect the router to the modem Connect the ethernet port on your broadband modem to the WAN port on the router.
Step 4: Check link lights and connections
Check the front of the router to make sure the Power, WAN and LAN1 lights are on.
Jun 29, 2008 | Computers & Internet
How do i connect up my router
All LAN Ports are ON
Arunk, When you say the electrical characteristics of the new A/C adaptor are the same as the old one did you check to ensure the amperage and the polarity of the power plug is the same as well?
Apr 03, 2007 | NetGear WGR614 Router
NetGear RangeMax WPN824 Router Logo
55 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
