Question about Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black
Replacing the ceramic cook top on my Frigidaire CFES365EC6
I need to replace the ceramic cook top on my
Frigidaire range model cfes365ec6
I have ordered the new top and I'm looking for a how to
Looks as though once i remove the old top by pulling the broken pieces apart and off the gasket
then cleaning the sheet metal on the range to
accept the new gasket and pop the new top on
Any guidance would be much appreciated
Thank you
5 Suggested Answers
  • 2651 Answers
SOURCE: Frigidaire CFEF372ES1
its an electronic latch, try pushing the self-clean button, ti will try to lock and unlock the door- if successful the oven will begin to clean immediatly push the cancel button and will unlock,
Posted on Feb 26, 2008
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
  • 1531 Answers
SOURCE: Frigidaire FEFB78DCD range wont heat but display and lights work
you need to check all the wiring.the main control board should be replaced.
Posted on Mar 06, 2010
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Posted on Sep 05, 2010
yes u can,, most have 5yr parts warrantys though i would check your manual or get ur purchase date,, DO NOT tell them u broke it as it doesnt relate to consumer accidents.. just say u were cooking and heard it shatter if its under warranty.....most glass cooktops can vary anywhere form 200-400 dollars ive seen some geprofile cooktoops glass tops up to 900 dollars just for the glass.......... It is possible to replace most are expensive and most are backordered parts occasionally manufactures might stock the item it just relates to your particualr model number.... you can do this also but will have to transfer elements over to new glass,, u may want service one this *** all wiring and elements must be mounted exactly the same as removed .. hope this helps
Feb 05, 2010 | Frigidaire FEF366 Electric Kitchen Range
GE profile top
Yes, the glass cook top can be replaced. These counter top inserts are actually fairly simple to repair, but the entire assembly usually has to be uninstalled to accomodate removing the glass top and installing a new one. You will need to provide a model number by opening the cabinet underneath the cook top and looking for a nameplate in order for me to assist you further in determing a part number, cost and how to disassemble.
Aug 19, 2009 | Frigidaire FEF366 Electric Kitchen Range
Replacing the ceramic cooktop on my frigidaire slide in stove
there is no need of any instruction booklet for your problem, but a cooking range repair man.
He will replace it for you.
Mar 20, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Replace ceramic glass top maytag eletric range
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 19, 2009 | Frigidaire FEF366 Electric Kitchen Range
How to get grease stains off
Hi, Is this a glass top type? If it is then DO NOT use any abrasives, soft scrub, ect. Use a razor scraper like for paint and keep it flat. Then purchase any commercial glass/ceramic cook top cleaner (grocery or hardware or diy store) and use a drop about the size of a dime on each burner. Fold a couple of paper towels and in a circular motion buff the top and when it looks clean turn the towels over on to the dry side and polish it to like new. Good Luck!
Feb 02, 2009 | Frigidaire FGF316 Gas Kitchen Range
Replace cooktop
looking at the part breakdown for this unit, doesnt appear to be much a of a problem in replacing the top, teh gasket should come with the new top if not there is one available for purchase, but looks as if all you need to do is remove the frame(look as if 2 screws in either rear corner will release this)afeter that the glass should lift right up simply replace with new and re-secure the screws, be gentile however the new glass can be fragile, so make sure ut fully sits flat in the spot before trying to tighten back into place
Dec 15, 2008 | KitchenAid KERC508LSS Electric Kitchen...
I have cracked half of my ceramic stove top and am wondering if I can use the other half until I get it replaced? Also, I am wondering what the cost of replacing the ceramic cook top would be?
You can but its not a great idea. The heating and cooling of the surface burners will just crack it even worse. I wouldnt advise you to use it. But it can be used for very minimal cooking.
Nov 14, 2008 | Frigidaire Kitchen Ranges
I bought a Frigidare 30" Freestanding electric range model # FEFL79HB in July. I really like the flat glass top but have had problems trying to clean spills off of the top. Residue from cooked food...
Scotch brite has your solution they have a kit for cleaning ceramic cook tops ..
cook top cleaner kit
go to
there is also a coupon you can print out.
let me know if it works for you just like it did for me..
Sep 09, 2008 | Frigidaire Kitchen Ranges
Replace ceramic top on gas range
yes the part number that you need to order is 316251903
Apr 13, 2008 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Logo
123 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
