Question about Canon MP520 All-In-One InkJet Photo Printer
Canon MP520. Printing horizontal lines are stepwise.
How to do the alignment to get best horizontal lines printing? The problem is that all horizontal lines in printing documents are stepwise.
  • 125 Answers
SOURCE: horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Posted on Apr 23, 2008
freetek
  • 5568 Answers
SOURCE: White lines across text on Canon MX700
It sounds very much like a failed printhead or printhead driver; the circuit that controls which jet is addressed or left blank.
Posted on Feb 12, 2009
  • 62 Answers
SOURCE: Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Posted on Feb 13, 2010
Douw
  • 91 Answers
SOURCE: canon Pixma IP4200 started printing regular
Hello first of all are you technical
I have taken the printer head out
boil some water and pour in a cup
take off the 2 screws at the bottom
gentley open the head from the casing**** note if you not gentley it wil brake and U can through the hole head away
then let the white block lie in in the water until the water is cold the trough that out and repeat this step.Boil water again....Wait for 4 to 5 minutes to pass..... then use high copressed air and blow from the underneth so that the presure will force the **** out on the white block side also force some hot water from the litle sifes at the top down and make sure that holes are open
replace the ruber perfectley and the head pease an make sure every thing is propeley dry.Replase the scews .and put it back in the printer.Remember it is also a very filthey and inkey job.Good luck
Posted on Feb 15, 2010
pineworks
  • 4041 Answers
SOURCE: Canon pixma mp140 not printing correctly
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Mar 11, 2010
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
Printer is printing photos with visible horizontal lines
If the inks in those cartridge are still enough for print, you need to clean the head. For this follow me :
1. From the Printing Preference window (the window where you used to set paper type, paper size .....) choose the Maintenance tab.
2. On that Tab, you will see some tools, click on the CLEANING button, load a paper in the printer, after cleaning the printer will print some patterns, repeat till you satisfied with.
3. If the problem persist, try DEEP CLEANING.
4. Also perform a PRINT HEAD ALIGNMENT by following the onscreen instructions.
Oct 13, 2010 | Canon MP520 All-In-One InkJet Photo...
Cannon MP520 when printing documents there are lines through some of the text. I have changed the ink cartridge 2 times! What should I do?
The issue is not with the ink cartridge but with the actual print heads. In most (almost all) Canon ink jet prints/multi functions the prints heads are separate from the ink cartridge.
The print head is what guides he ink onto the page, if they become dirty or clogged then you will get lines through images and text or very poor print outs.
You can clean the print heads by using the software that came with the printer and there are some other ways as well.
I tried to paste the instructions from Canons site but they were too long. Use the link below to go to Canon's knowledge base for the MP520 and search for "clean print heads" and follow the instructions that come up.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15483
Apr 14, 2010 | Canon PIXMA MP520 InkJet Printer
I am always getting horizontal lines on anything I'm printing these days - how can I fix the problem
Go to your printing preferences page and run your tools (aligning print cartridges, cleaning print heads etc.) consult your owners manual or check the Canon website under support. Also check your ink levels.Hope this helps and good luck.- jmattes
Oct 20, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Horizontal printing not straight
Have you cleaned or replaced the printhead recently?
Mar 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Horizontal lines in pictures
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
IP 4300 Canon Printer printing horisontal gray lines
To solve this problema, proceed with LF correction procedure, which is well documented on Canon IP4300 simplified service manual (it can be found at Emule network). This procedure prints some patterns and the user has to choose the best among them. One of them will probably enough to compensate (or, at least, to minimize the problem to the point that naked eyes can't observe it) the line feeding error which causes dark horizontal lines along the printer lifetime (probably because of feed roller wearing).
Jan 22, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon MP520 All-In-One InkJet Photo Printer Logo
132 people viewed this question
old marine
old marine
