Question about Mitsubishi WS-55515 55" Rear Projection HDTV
Blinking green power light & shut down
I have a Mitsubishi WS-55515 - over the past few months when I turned on the unit, the green light would blink and the unit would shut down. Ater a few minutes, I would be able to turn on power normally. Now, when I turn on the unit, the green light blinks and the unit shuts off immediately. I have tried to hit reset, and I waited for the green light to stop blinking, but when I turned on the power, the green light blinked, and shut down again. I have tried to reset several times, and power up several times. The unit now never fully powers up with a picture or sound. Is this a power supply issue or the capacitors I have read about. If this is the capacitors could you please tell me what specific capacitors I have to replace. Thanks for you assistance.
Brandon
  • Mitsubishi Master
  • 8,617 Answers
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Posted on Apr 07, 2008
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
I have a mitsubishi WS-55515 . the green light blinks continously and it doesn't respond to any thing
This unit s common problem is a fluid leak on the chasey from one or more of the tubes it leaks on the chasey maybe only one or two drops but after a period of time it causes a corrosion on the chasey and things like this happen you have to get a lamp or flash light and look in the tv to see if this is happening be surre to unplug tv
May 19, 2010 | Mitsubishi WS-55515 55" Rear Projection...
Won't turn on after reset ws-55511 hdtv
YOU GOTTA REPLCE THE STK ICS OR THE CAPS ON THE DM BOARD
Jul 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light mitsu ws-55515 rptv
if the set is shutting down it should blink a code. Try pushing in the menu and input buttons on the set both at the same time and hold them in for 8 seconds to see if the self diagnosis will falsh a two digit code. Let me know what happens
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi ws-55515 light blinking
Sounds like the remote is not programed correctly or the input sources have been changed.
Call the cable company and complain that it worked before they came and shoud work afterwards.
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-55515 55" Rear Projection HDTV Logo
342 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
