Question about Brother IntelliFax-4100e Fax
How do I change the modem speed on the Intellifax 4100e
    President:
  • 3,085 Answers
You can't, plus it won't work on a digital phone line anyway
Posted on May 27, 2010
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
Thanx,
Mar 22, 2011 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e There is a message on the screen to change drum, and I already changed it. Also, there is a squeggy noize everytime we receive a fax. I tried taking the drum, carthridge and I...
1. Open the front cover and then
press Clear.
2. Press 1 to reset.
However, the drum may be defective and causing the noise. Try a different one if you can.
Nov 16, 2010 | Brother IntelliFax-4100e Fax
IntelliFax-4100e
go into menu, arrow over until you see 2. Fax hit set, then arrow until you see 1. one-touch speed dial, then hit set. touch the one-touch button you want to change, then the number 1 to change it, it will display the number, hit clear to delete it then dial the new number hit set and you're done.
Feb 11, 2010 | Brother IntelliFax-4100e Fax
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Nov 07, 2009 | Brother IntelliFax-4100e Fax
Changing a speed dial number
Use menu 2.3.2 to access the number you wish to change. Use the cursor (left and right arrows)to go to the number(s) you need to change, When the cursor is under the digit that needs changing, type in the new number. Continue this process until the number reads correctly. Press SET afterward and the new number should now be saved. Hope this answers your question. All the best!
Greg
p.s. Here is a link to the user guide for your machine: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Jun 17, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax-4100e changing Pick up roller
Push the arms that limits the lifting up of the feeder outboard to release the freeder.
Feb 05, 2009 | Brother IntelliFax-4100e Fax
Fax Problem
Once you have changed the drum unit on Brother 4100 you will need to keep the front door open and then press the option button. Your dispay should give show you a drum change option. press 1 to change drum and the machine should show "accepted" after a few seconds. Afterwards, close the door.
Oct 28, 2008 | Brother IntelliFax-4100e Fax
Cannot receive fax with voip line.
Fax machines are ANALOG devices. Any other condition is a ****-shoot.
Aug 12, 2008 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Logo
402 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
