Question about Amana AP095R Portable Air Conditioner
I am looking for the attachement that conects the exhaust hose to the ac unit i ve lost mine any suggestions
  • 36 Answers
Try contaxting Amana Directly. www.amana-hac.com
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729 or use some duct tape and cardboard.
Posted on May 27, 2010
Dyson DC14 hose won't extend and floor unit lost suction
Sounds like the exhaust side is clogged. Remember a vacuum pulls air into the cavity, but for it to work properly it also has to be able to exhaust the same amount of air it takes in. If the exhaust is blocked it will continue to suck air inside and collapse on itself, which is why your hoses are getting shorter and harder to move. Check the exhaust system for any blockages, perhaps the hole you taped was the exhaust.
Mar 15, 2015 | Dyson Vacuums
Where is the heater core located and how to change the heater core on a 2000 Nissan frontier 2.4 L cylinder
If it has a AC you have to pump down the AC remove the entire heater and AC unit so you can disconect AC lines and heater hoses ,you have to drop the steering column and remove the glove box, its a big job I would buy a manual so you know what all you have to disconect.
Mar 02, 2015 | 2000 Nissan Frontier
Does exhaust hose needed for all modes of ac?
Yes. This will exhaust the heat from the condenser and humidity (condensate) from the unit.
Sep 11, 2014 | Haier Heating & Cooling
Portable air conditioner rattling
not sure i use mine without exhaust hose
Feb 21, 2014 | Amana AP095R Portable Air Conditioner
I have a unit with no exhauste hose conecter and no nozzel fitting covers or a window panel
Sadly this company seems to be out of business and parts unavailable. You can get vent hose at lowes. I attached the hose to a unit with a couple of small metal brackets, zip ties and vent tape. For the window part, I cut a piece of plywood, painted it white and cut a hole for the vent hose. Attached it with zip ties and silver vent tape.
May 24, 2012 | Windchaser PAC9 Air Conditioner
Samsung#DV448AGW/XAA check filter light on
Hello. #1-Use a vacuum cleaner with hose attached and vac the drum vent screen inside the drum. #2-disconnect AC power(unplug or switch off 220volt breaker) carefully remove hose from air duck of dryer and vac inside of dryer. Vac the hose and exhaust port. Reattach hose, reconnect AC power and test operation. #3-Problem still present the exhaust sensor or the (most likely) the exhaust fan not working properly. Good Luck!
Feb 28, 2012 | Samsung DV448AGE Gas Dryer
Where is the fan control module and the ac high pressure switch on an 02 vw golf?
the fan control unit at front r/h chassis from down or flow fan motor cable it;s conect with control
A/C pressure S.W look to two freon hoses gose to body if you folow you find the presure s.w conect with socet 3 wire can be replace without lose freon .
Jun 19, 2011 | 2001 Volkswagen Jetta TDI
Just purchased a 15000 btu 110 Frigidaire window unit and we love it. However, since the rear of the AC is actually on the back porch, the water from the AC runs down the wall and on to the floor. We could...
window units slide into an outside frame section
there is a hose attachment area at the back of the ac unit proper that a hose can be attached to
and there should be a section in the frame that allows the hose to be fitted to that ac unit proper
the unit should be mounted so that it actually slopes slightly down at the rear so water can collect at that drain point
there are adaptors that should have come in the packing box for hose attachment
if not, many people use white poly piping or electrical conduit with suitable elbows to collect the water at the hole and pipe it back to the wall into a bucket and the collected water used to water plants and gardens
May 02, 2017 | Frigidaire FAC126P1 wall/window Air...
Decreased suction
you might have a clog, to try and unclog the lines, you need to unplug the unit, and remove the bag compartment. Then take a shop vac using the hose attachment hold it into the attachment door where there is low suction and try to draw the clog out the way it went in.
May 09, 2009 | Broan-NuTone CV353 Central Vacuum
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Amana AP095R Portable Air Conditioner Logo
213 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
