Question about Sanyo DS25390 TV
What channel does it need to be on to play a dvd player I have the converter box
  • Sanyo Master
  • 8,457 Answers
Ur tv have a video input holes R,Y,W.?Use the RCA cable R,Y,W to hook up to play the DVD player.Use the tv video 1 input to watch dvd movie.
Posted on May 27, 2010
How do I get Panasonic TV/Vcr combo PV-c2021 to play DVD player using converter box? How do I get TV to display that input? Nothing displays on channels 3 or 4.
Make sure that you converter box (scan converter) can reduce from 1080 p to 480i. If it can that what you need to do is plug the output of your DVD player to the input of the converter. Then from the output of the converter to the tv. If you plug into Input 1 on your tv then you need to switch the input with your remote. There should be an INPUT or a SOURCE button that lets you toggle between them.
Mar 01, 2015 | Panasonic Televison & Video
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
I have rca STB7766G1 converter box can I connect my dvd player
Trial and error. There is no list of products that will work together and how, so when you have situations that come up such as these you have to connect the electronic devices and see what happens. What's worse is that the combination will not always work with the same brands and even if you do get this to work today it might not work tomorrow.
Ok connect the DVD player to the television. Where it says out on the DVD player you connect the connecting cables either yellow, white, and red or green, blue, red, white, red. You connect the other end of them to the television. Put the television on the correct input. Try playing a movie to make sure the dvd player and television are connected properly.
Ok now where it says IN on the DVD player. Connect a yellow, red, and white cable. The other end of that cable connects to the converter box where it says out.
You can also connect the converter box and the dvd player in this way if applicable. If the dvd player has an RF (coax) IN connect a coaxial cable there and connect it to where it says OUT on the converter box.
Then you connect an antenna to where it says ANTENNA IN on the converter box. Now you will have to be able to put your dvd player in input (aux) or turn it to channel 3. You will always leave your dvd player in input (aux) or on channel 3. You will only change channels on the converter box with its remote control or the buttons directly on it. Good luck!
Apr 23, 2011 | Televison & Video
Trying to get unit to play
well try unplugging everything then set it back up and switch some cords around....if nothing happens take then or it back ...best of luck :)
Aug 16, 2009 | Cyberhome CH-DVD 300 DVD Player
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Hi Karen, I think you are having connection issues. Can you provide specific details of the connections? Thanks, Mike
Nov 02, 2008 | Philips Magnavox DVD/VCR Dual Player
SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Nov 02, 2008 | Sony DVP-NS57P
Dvd player/recorder DRW 500 does not pick up channels after installing DTV converter box. it will record directly but can't be set for timed recording because it did not find channels
You want to set the recorder timer to record the out put channel of the converter box (either 3 or 4 ) then tune your converter box to the channel you want to record, and leave the converter box turned on until you are done with the timed recording.
Jun 30, 2008 | Televison & Video
Televison & Video Logo
142 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
