Question about HP Pavilion a1700n PC Desktop
How to tell if a motherboard is toast?
About 2 months ago I put my HP a1700n away in storage because it was taking up to much room. It worked perfectly. I pulled it out the other day to set it up, and i plugged it into my surge protector and turned it on. It was showing power on the power supply, but the front on off button wasnt working. I took it to a tech and he put in a new 680 W power supply and said it still wasnt working. He tested the mother board and said it was fried. How does the mother board get toasted when I put it away and it was working and now it doesnt work? I tried to jump the on/off switch on the front and still nothing. How does one test a motherboard.
    Problem Solver:
  • 4 Answers
Sounds like when you removed it from storage and reconected the wires is it possible there was alittle moisture (condensation) built upon the motherboard and when you plugged it in and tried to power it up it fried. When electronics are stored somewhere not at or close to normal room temps when reintroduced into a normal room temp enviroment moisture can condense and accumulate. enough to cause a short and thats all she wrote. All you needed to do is let it acclimate for a while depending on the storage temps to normal room temp difference. The bigger the difference the longer wait, the lower the difference the less time needed to wait. You can even submerge the whole pc and as long as you get as much of the water out of it as possible then let dry at room temp thoroughly and completely ( i can't stress that enough). You can even use a hair dryer to help in getting the moisture out (use on low at close range or high from 10 to 12 inches away from motherboard and other componants).You should be able to start it up with only very minor problems if any. Again," COMPLETELY DRY" if you have to wait 2-3 weeks to be sure then wait! Better safe than sorry! Hope this helps someone. Good Luck!
Posted on Feb 24, 2012
  • 428 Answers
May be a fault on the connection with the surge. Connector leakage might be. And of course the power unit it might be. One or both as I feel made the trouble. There are various methods to test mother boards. Most simple method is to check each and every component on the board using a separate motherboard or using component testers.
Posted on May 28, 2010
  • heathensandy Feb 27, 2011
    it seems like it is set to boot from your cd-rom instead of a normal boot up
Channel 4 stopped working. No other problems.
Hi Harold
TV may have simply lost the ch4 frequency from memory.
My TV did this 2 months ago and it blew me away as all other stations were fine.
Put it down to Cosmic Rays!
Simply run the Automatic Station Finder from the main settings menu. This will reload all receivable stations back into it's internal memory storage again.
Other than that.... is ch4 still on air.
Good Luck
Jan 03, 2016 | LG 24LN4510 24" 720p LED-LCD TV - 16:9 -...
Why do I keep getting notices that my storage is allmost full?i recently bought more gig a bites about a month ago,storage should last for years! Don't understand!
If you mean in I cloud I will you still have Iphone or iPads in your iCloud you no longer have if you remove them it will give you more room but if you have had one stolen removing it will let them restore it hope this helps
Feb 22, 2015 | Apple iPad 2
Dont know the functions of front face usb and mini inputs for HP Pavillion a1700n
To burn a CD you need a CD-burner. The front input are not required to burn a cd.
Aug 03, 2012 | HP Pavilion a1700n PC Desktop
I have a HP pavilion a1700n and the dvd quit working. I bought a hp dvd/cd writer 1270i. This unit has SATA connection. I noticed that my a1700n has an unused SATA connector and there are three unused...
A SATA hard drive needs to be pugged into a SATA port on the motherboard. They're the "L" shaped ports. They look like this: moondogwst75_2.jpg
The little blue ports. The hard drive should have come with the appropriate cable. Other than that, just plug in a SATA power connector to your hard drive and you should be golden. Hope this helps!
Aug 27, 2011 | HP Pavilion a1700n PC Desktop
Hi I have a HP pavillion DV6 iv'e had it for about 2 years and it wont turn on. I had it on once about 2 months ago after i researched a solotuion to the problem but after i turned it off again it wouldnt...
Hardware failure: the chipset of the motherboard has overheated and failed. You will need to take it to a repair shop, you will probably gonna have to replace the motherboard.
Feb 14, 2011 | HP Pavilion dv6000z Notebook
Printer constantly stays on....Shows E... red blinking light shows check printer cartridge
Try to carefully clean off the contacts on the back of each printer cartridge with a soft, damp, lint-free cloth. Then re-seat the cartridges into the carriage and see if that works. If not, try to power cycle the printer. Unplug it completely from the power for at least 10 minutes. Come back and plug it in. If it doesn't work, it's probably toast. You're lucky it's lasted this long. I had my exact same model printer go out two months ago. Unfortunately, they were made to be thrown away. Not really able to be fixed.
Nov 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
I got 256mb internal ram and i put 1gb external ram on my hp compaq nx6110 laptop and after few months my hard disk stops working. so now i want to buy a new hard disk so how many gb of hard disk i should...
I think you're confusing RAM (memory) with hard disk space (storage). Installing more RAM makes your computer run faster. More hard disk space gives you more room to store stuff. Which would you like to do?
Apr 03, 2010 | HP Compaq nx6110 Notebook
The wires going to the voltage regulator keep burning up.
Common problem with poor quality parts, the regulator is the problem, the generator is working other wise you would not have fried the wiring, you answered your own question. someone telling porkies to get more money from unsuspecting client?
The regulator controls the voltage not the generator, the generator only supplys the voltage it cannot overcharge unless the regulator is not working properly, simple!
Jul 27, 2009 | 2002 Yamaha V Star 1100 Custom
Hp pavilion m7330n motherboard issue
The system in question requires motherboard model ms-7184 and can be found on ebay for less than $100.  If your repair guy used a different motherboard you will get the issues described and need to reinstall the OS.  It is impracticle to put any more than $200 in most desktop computers more than 2 years old, your repair guy should have advised you of this straight off.  Find a new person to take your equipment.
Jun 27, 2008 | HP Pavilion Media Center TV m7330n...
Display will not light
im pretty sure when it was put away in storage for a few months it probably got dust in it that might have caused the lighting to not work.... i couldnt see why no one could help you in the place where you got from... they could probably take a look at it!!
Oct 22, 2007 | Philips GoGear SA178 MP3 Player
HP Pavilion a1700n PC Desktop Logo
157 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
