Question about LG LS-L1210CL Mini Split Air Conditioner
Problem with compressor
I have LG split air conditioner. whenever i turn the ac on compressor shuts down after 10-15 minutes. it gets too hot. well fan in outdoor unit keeps on running . when compressor cools down after an hour or so it turns on again and turns off again after 10-15 min. i have replaced capacitor, and an expert has washed its indoor and out door units capillaries . but problem still exists,
    New Friend:
  • 9 Answers
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
Posted on Jun 03, 2010
  • Knight May 25, 2014
    Yeah my room is too big and have same problom so what is the remedy for this problem ??
    New Friend:
  • 39 Answers
First check the voltage and replace the relay check the capacitor u already chanched that valuve is same or not maximum prolem is in capacitor only
Posted on Mar 30, 2015
Klimaire KSWG012H113 Split System Air Conditioner
Check web site for significance of the four flashes. Could be that it is overheating and shutting down due to excessive current consumption.
Jul 24, 2016 | SNK Klimaire KSWG012H113 Split System Air...
My LG lp1010snr AC's compressor only seems to run for about 3 minutes on and 3 minutes off, is the compressor being this intermittent normal or is there a problem?
This is called short cycling and it is a problem. It sounds like the compressor is getting hot and shutting off on a thermal overload. When the overload (bi-metal contacts) cool from the compressor being off they close and the compressor begins running again. The refrigerant gas cools your compressor windings, so there may a restriction present or a leak, which would cause the compressor to get hot and open on overload. This is not good for the compressor and will eventually ruin it.
Aug 03, 2011 | LG Heating & Cooling
My split system keeps kicking out it runs for a while if i shut down and restart but compressor kicks out after 5 min. it is contrlled with remote
The unit is usually low on freon when this happens...the machine will over ride the freeze stat and the low pressure control for five minutes and then shut down...
Have a tech. check the system for leaks and repair them.
Then recharge the system and you'll be good to go...
heatman101
Jul 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My 1.5 ton,LG split AC shuts off rather
Hello
First the foam insulation is not just for looks,you will have some loss of cooling on the unit,the larger cooper line needs to be insulated,the small one does not.The large line is the suction line,the small one the liquid line.
Voltage,168 is low,sounds like a 208 volt unit or 220 volt.running at 168 or 198 ac volts is going to raise the amperage causing the compressor to run hot and work harder and soon burn up,And cause it to trip the breaker or shut itsself down on high heat.Your going to need to get that voltage fixed.I dont know why it needs a stabilizer if the unit was sized correctly it shouldnt need one.
Hope this helps.
Apr 14, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Compressor keeps shutting off after 30mins or so
The system may be going into cool down mode or thermal over load if the temperature is 104 degrees fahrenheit or above since the compressor will shut down if the internal temperature reaches 165 degrees.This could also be from low oil in the compressor.
May 19, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
E4 in an innovair a/c
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
My AC
One might think so, YES the compressor is running till it gets hot and tripps on hi-temperature, and after it cools down awhile, the switch willcautomatically reset itself and back- & forth......Thank-you-very much!
Jul 25, 2008 | GE Zoneline AZ38H12DAD Split System Air...
LG LS-L1210CL Mini Split Air Conditioner Logo
593 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
