Question about HP DeskJet 5550 InkJet Printer
HP doesn't recognize black cartridge, Mac user
Same problem, same attempt to solve (replaced cartridge) but no improvement!
  • 61 Answers
If you are using a remanufactured cartridge, exchange it in the store, cause it is with problem on it´s internal circuit.
Posted on Apr 19, 2008
SOURCE:
I have changed out my black ink cartridge and now it says Attention: Print head loose, missing or not installed correctly.
Had exactly the same issue - working fine until ink cartridge changed (kodak for kodak - not a copy). Then can only get 'print head error message'.
Multiple attempts to remove and re-install, power on/off etc. but can't shift the error message. New print head more expensive than a new printer!
May 06, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
Hp dj 800 ink supply station not recognize black cartridge
Does it show a Flashing X for the Black?
1 Replace the Ink Cartridge that has failed.
2 If the message continues to appear, clean the electrical contacts
inside the Ink Supply Station (power OFF the Printer first).
3 If the message continues to appear after cleaning the Ink Supply
Station, replace the Ink cartridge again.
Mar 09, 2014 | HP DesignJet 800 Printer
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 27, 2013 | HP Deskjet 6988 Inkjet Printer - Color -...
HP 5150 Deskjet -- black printing abruptly stopped. Prints appear with color but no black. Switching black cartridges doesn't help. Clean print heads operation doesn't help. Switching computers...
There are very few things you can do, other than what you have aleady done.
I would recommend a decision on how much the unit cost and how long you have used the
printer vrs. what HP or a local authorized service center would charge to repair it.
If you have refilled ink cartridges, this is problem that can arise due to ink drying on the
print head as the black cartridge is use the most.
Aug 06, 2011 | HP DeskJet 5150 InkJet Printer
My printer keeps flashing check print cartridge, Both black and color are flashing. I have Just bought a new 92 Black cartridge and the color cartridge is full ... why is this happening?
While reseating a cartridge is not difficult but there are a number of errors that can occur if the user does not manage it properly. Reseating a cartridge should not be a difficult task for anyone with a passing knowledge of printers. The reseating error can occur after the user has replaced the black ink cartridge. It is a common problem with the black ink cartridge. The user may attempt to replace the cartridge number of times, clean the contacts and restart the plotter. If there is a problem with replacing the black ink cartridge that cleaning the contact does not fix, then it is best to simply replace the carriage assembly first. If this does not solve the problem then the user may want to consider replacing the trailing cable.
Nov 17, 2010 | HP Office Equipment & Supplies
Hp F4280 can't recognize a black cartridge after refilling it. What can I solve the problem? Please help me!!
If the printer not recognize it, that mean the cartridge are failed electrically and you need to replace it.There is an another option.After refilling printer will recognize cartridge like empty but it will printing.
Nov 17, 2009 | HP DeskJet F4280 All In One Printer InkJet
3940 blinks and cant pritn
hello lotsaprint, ipang
Few days ago i had the same problem with my hp 3920 color photo printer. All i did is removed the cartridges one by one and the problem was solved. Try removing the color cartridge first, then switch on the printer see i the problem is solved the cartridge contacts must be dirty. clean it with soft tissue (dont use any liquid) and reinsert the cartridge. If the problem persists u may need to replace the cartridge. Check with a new one if u can borrow one from anyone b4 u buy.
Repeat the same procedure with black cartridge if necessary. If u r new and need guidance for removing the cartridge, then do the following.
1). Switch on the printer.
2). Open the front cover. The cartridge will now move to the
center.
3). Switch off the printer and remove the power cord.
4). push the cartridge gently downwards to detach.
Close the cover when u r done with above mentioned.
For more info see the user guide u go with the printer.
Hope this was helpful
anishpillai2
May 05, 2009 | HP DeskJet 3940 InkJet Photo Printer
HP Laserjet 3005DN toner cartridge change
You don't. HP printers seem to be very particular about this.  Take it back and get the exact replacment, including the brand.
Jan 20, 2009 | HP LaserJet P3005n Printer
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
The printer is not recognizing the black print cartridge. It is an official hp black 59 (19ml) cartridge but it still does not recognize it and therefore will not print. My printers is an HP 1215...
Your printer does not use #59 Cartridge!!!!
HP 56 black print cartridge (19 ml) C6656A HP 57 tri-color print cartridge (17 ml) C6657A HP 27 low capacity black print cartridge (10 ml) C8727A HP 28 low capacity tri-color print cartridge (8ml) C8728A
Sep 24, 2008 | HP Office Equipment & Supplies
HP DeskJet 5550 InkJet Printer Logo
107 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
