Question about Toshiba Satellite A135-S4527 Notebook
Dimmed lcd my toshiba amilo 3438g shows a very dim screen.can you give me any ideathank you for your kind assistance
    Sergeant:
    Champion:
  • 256 Answers
Look for an icon on your keyboard that shows brightness like a sun drawn on the keys. try pressing that together with Fn key, or if you cant see that icon, try fn key and up arrow key or right arrow key. See if that one would work.
Posted on May 27, 2010
Screen flickers and color wont show
What kind of cable are you using, and how long is it? Does it work for connecting the PC to a monitor? And are there any splitters on the line?
Jan 30, 2014 | Hitachi CP-X253 Projector
Toshiba laptop display goes dim
If you are operating on battery this is a power saving mode. Go into setting and see what the power settings are. Try running on charger and see if this still happens.
Oct 20, 2017 | Computers & Internet
Satellite L45-S7409, Screen is very dim.
Try reseating the lcd cable on the back of the LCD and also where it plugs into the motherboard. If you still can't get a normal screen and it stays dim then its going to be either your lcd is bad or the inverter that supplies the voltage to the lcd (inverter is located underneath the lcd, small rectangular board) is bad.
Aug 08, 2009 | Toshiba Computers & Internet
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 18, 2009 | Toshiba Satellite 4090XDVD Notebook
Have a P105 S6164 bought used lcd screen very dim
With the replacement screen did you replace the inverter board? Many laptop screens also have a very small fuse built into their power connecttions. Check this also.
Apr 03, 2009 | Toshiba Satellite P105-S6104 Notebook
My toshiba laptop is not giving the display at all?
Does the computer boot up?
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 13, 2009 | Toshiba Satellite Pro L300D-EZ1006V...
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
Toshiba Satellite A50 (A55) Dim screen
what you are describing sounds lile the inverter coil, but you sat you have changed the whole inverter!!
plug the laptop up to an external monitor and please post back
regards
Dec 04, 2008 | Fujitsu AMILO M-6500 Notebook
Toshiba equium A100-306
try function key for lcd it may be in presetaiton mode by mistake
or is lcd on / come on bright then go dim / dark just very dim if so your backlight is out replace lcd
Oct 24, 2008 | Toshiba Equium 7100S PC Desktop
Toshiba Satellite A135-S4527 Notebook Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
