Question about Toshiba E-Studio 3511 Color Copier
Toshiba estudio 3511 keeps giving error c360. I've checked the charger and the gears are messed with drive motor. Motor turns initially but gets to stopping point and gives error. Is there a charger position sensor that should be checked?
    Sniper:
  • 66 Answers
At our repair shop we have begun to put a small (1/8" or so) washer in between the frame and the bracket the worm gear is attached to when we get this error intermittently. It seems to pull that worm gear closer to the main charge cleaner gear to give it better meshing. Hopefully this helps you!
Posted on Aug 17, 2010
It is blocked to call SAV,when i do clear+8 i have error C970.Please what is the solution?
C970 Process related service call High-voltage transformer abnormality: Leakage of the main charger is detected.
[C970] High-voltage transformer abnormality (1) Is the main charger installed securely? (2) Check if the spring of high-voltage supply contact point is deformed. (3) Check if the charger wire is broken or the main charger grid is deformed. (4) Check if any foreign matter is on the charger wire or main charger grid.
Jun 23, 2015 | Toshiba E-Studio 3511 Color Copier
How to reset cdfo error toshiba estudio 355se
CDF0 Offset tray related
service call
Initialization error of the offset tray: The home position of
the separator cannot be detected when the power is
turned ON.
[CDF0] Initialize error of the offset tray (e-STUDIO205L/255/305)
(1) Check if each connector between the OCT motor and OCT board (CN261) is disconnected.
(2) Check if each connector between the OCT board (CN261) and LGC board (CN302) is
disconnected.
(3) Check if each connector pin is removed or the harness is broken.
(4) Check if any conductor pattern on the OCT board and LGC board is short circuited or open
circuited.
(5) Replace the OCT motor.
(6) Replace the OCT board.
(7) Replace the LGC board.
Oct 31, 2013 | Toshiba e-Studio 350 Copier
HI! I have one machine Toshiba C350 this is Color
Hello
The error code that is displaying, is the charger cleaner motor abnormality: Charger cleaner motor is not rotating or the wire cleaner is not moving normally.
Please try the following.
(1) Check if the main charger is installed normally.
(2) Check if the charger wire is broken.
(3)Check if any of the connector pins of the charger cleaner front/rear position detection switch is disconnected.
(4) Check if the cleaning pads are damaged or removed.
(5) Check if any of the connector pins of the charger cleaner motor is disconnected.
(6) Replace the charger cleaner motor.
(7) Replace the Logic board.
I hope this helps a bit
Regards
May 23, 2011 | Toshiba e-Studio 350 Copier
I have a Toshiba EStudio 3511. It is giving a message saying Service Required. I hit clear and number 8 and I get error code F070. How do I fix this? I tried turning it off and on several times even from...
f070 communication error between system cpu and main cpu
firstly try updating the firmware version
then possibly replace the system board and or lgc board good luck
Mar 23, 2011 | Toshiba E-STUDIO 850 Copier
Como instalar el escaner del una toshiba estudio
buenas noches quiero sabe como scanear en la multifuncuional toshiba 2330c y hacia que carpeta direcciona los documentos gracias
Mar 20, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 error c360
C360 indicates Charger cleaner motor abnormality. Make sure the charger unit is installed & engaged to the drive gear. It is a common problem on e3511 model, where the main charger unit will loose.
Feb 05, 2010 | Toshiba E-Studio 3511 Color Copier
My Toshiba e-studio 3511 gives me a C010 error, what does that mean??
C010 indicates main motor abnormality.
U need to perform output check 03-101(ON)/151(OFF) to off the main motor. If main motor not running under output test, probably u need to replace it.
If motor working, u might need change the LGC board.
Jun 24, 2009 | Toshiba E-Studio 3511 Color Copier
Estudio 3511 empty waste toner problem
Hello sir;You have to empty waste toner container, it located at the end of the drum unit.
Jan 05, 2009 | Toshiba Estudio 200L Copier
Toshiba E-Studio 3511 Color Copier Logo
412 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
